Dayananda Posted February 27, 2020 Posted February 27, 2020 (entmod (subst (cons 10 LeftEnd1)(assoc 10 entlist) entlist)) (entmod (subst (cons 11 LeftEnd2)(assoc 11 entlist) entlist)) When I apply above codec to a vertical line it does not work properly. How can I add above codes to a one code. Quote
dlanorh Posted February 27, 2020 Posted February 27, 2020 Make yourself a function (defun dy:entmod (code val lst) (entmod (subst (cons code val) (assoc code lst) lst))) then (setq e_lst (entget ent)) (foreach x (list (list 10 leftEnd1) (list 11 leftend2)) (dy:entmod (car x) (cadr x) e_lst)) 1 Quote
Lee Mac Posted February 27, 2020 Posted February 27, 2020 (edited) The reason that your original code does not work as expected is because the second entmod expression is still operating on the original DXF list bound to the variable entlist and therefore you will receive a result whereby DXF group 11 has the new value, and DXF group 10 has reverted back to its original value. There are many ways around this, but the easiest & most readable might be: (setq entlist (subst (cons 10 LeftEnd1) (assoc 10 entlist) entlist) entlist (subst (cons 11 LeftEnd2) (assoc 11 entlist) entlist) ) (entmod entlist) Alternatively, you can nest the subst expressions, e.g.: (entmod (subst (cons 11 LeftEnd2) (assoc 11 entlist) (subst (cons 10 LeftEnd1) (assoc 10 entlist) entlist))) Edited February 27, 2020 by Lee Mac 1 Quote
ronjonp Posted February 27, 2020 Posted February 27, 2020 (edited) This should work too: (entmod (append entlist (list (cons 10 leftend1) (cons 11 leftend2)))) Edited February 27, 2020 by ronjonp 1 Quote
Lee Mac Posted February 27, 2020 Posted February 27, 2020 3 hours ago, ronjonp said: This should work too: (entmod (append entlist (list (cons 10 leftend1) (cons 11 leftend2)))) Just be aware that that method only works with certain entities, and won't work with entities which require subclass markers in the DXF data. 1 Quote
