I want to make this design, as you can see in the image below. But, as you can see in the video I have some problems:
 First, I dont know why dont recognise the command "S"(Select object) in the command Hatch (watch it in the video), and then I have to make a enter, because without this wouldnt keep running(I  dont  understand also why).
 Second, I just codified that a single hatch circle would add the color 171. But, (as you can see in the video) all circles are painted in color 171, less the circle I seted it. (circle 1)
Thanks if someone can help me. I am stucked. ðŸ˜Ÿ
  Quote
;CIRCLE 1 (the only circle I put a color in the hatch, but doesnt work)
  (setq R 0.0185);radio
  (setq P1ab (polar P1 (/ pi 2) (+ rec 0.02)));JUST A POINT TO HELP
  (setq P1a (polar p1ab pi (+(* rec2 2) R)));JUST A POINT TO HELP
   (entmakex (list '(0 . "CIRCLE") (cons 10 P1a) (cons 40 R) '(62 . 171)))
  (setq oldhat (getvar 'hpname))
  (setvar 'hpname "Solid")
  (setq oldcol (getvar 'cecolor))
  (setvar 'cecolor "171")
  (command "-hatch" "CO" 171 "" "s" (entlast) "" "");HERE I TRIED TO SET A COLOR TO THE HATCH, BUT AS YOU CAN SEE IN THE VIDEO: ALL CIRCLES ARE PAINTED LESS THIS
  (setvar 'hpname oldhat)
  (setvar 'cecolor oldcol)
;CIRCLE 2
  (setq P2a (polar p1a pi 0.18));JUST A POINT TO HELP
  (entmakex (list '(0 . "CIRCLE") (cons 10 P2a) (cons 40 R) '(62 . 171)))
  (command "-hatch" "s" (entlast) "" "");HERE I DIDNT TRY TO SET A COLOR TO THE HATCH
;CIRCLE 3
  (setq P3a (polar p2a pi 0.18));JUST A POINT TO HELP
  (entmakex (list '(0 . "CIRCLE") (cons 10 P3a) (cons 40 R) '(62 . 171)))
;CIRCLE 4
  (setq P4a (polar p3a pi 0.18));JUST A POINT TO HELP
  (entmakex (list '(0 . "CIRCLE") (cons 10 P4a) (cons 40 R) '(62 . 171)))
Expand
(entmakex (list '(0 . "DONUT") ………..Easier than hatching circle. Make inner rad real small 0.0001.
Using command may be ok and fast enough very simple questions.
Edited by BIGAL
  • Thanks 1
You could try this :
(defun rh:circlehatch (pt r lyr c hs / c_obj h_obj bound)
  (setq spc (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
        c_obj (vlax-invoke spc 'addcircle pt r)
        h_obj (vlax-invoke spc 'addhatch acHatchObject hs :vlax-true)
        bound (vlax-make-safearray vlax-vbObject '(0 . 0))
  );end_setq
  (vlax-safearray-put-element bound 0 c_obj)
  (vla-appendouterloop h_obj bound)
  (vla-evaluate h_obj)
  (foreach x (list c_obj h_obj) (mapcar '(lambda (y z) (vlax-put x y z)) (list 'layer 'color) (list lyr c)))
);end_defun
It is a function and you call it like this
(rh:circlehatch pt rad layer color hatch_pattern)
;pt is the centre of the circle )pt list)
;rad is circle radius (real)
;layer is the layer for the circle and hatch (string)
;color is the color for the circle and hatch (integer)
;hatch_pattern (string)
;example (rh:circlehatch (getpoint) pt 0.5 "0" 171 "Solid"); if bylayer color = 256 byblock color is 0
Edited by dlanorh
Agree with ronjonp.
Little mistake entmake a pline is actually a donut.
  • Thanks 1
