ShadyV Posted February 26, 2020 Share Posted February 26, 2020 This is what I am asking user picks a point (setq pt1 (getpoint "\npick point")) I want to do this.. if pt1 is a line or poly line save entity name as Blank else do nothing Is this something simple that I just cant figure out the correct way to write it? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 26, 2020 Share Posted February 26, 2020 (nentselp (getpoint)) 1 Quote Link to comment Share on other sites More sharing options...
ShadyV Posted February 27, 2020 Author Share Posted February 27, 2020 In case anyone wanted an answer on what I did... originally I did this after Ron gave me the link. (setq pt1 (getpoint "\npick START point")) (setq srt (nentselp pt1)) Then read a bit more and realized I only wanted it to save if it was a polyline and couldn't get nentselp to work right for me so went with (setq pt1 (getpoint "\npick START point")) (setq srt (ssget pt1 '((0 . "LWPOLYLINE"))) Thanks for the push down the right path Ron. So many different ways to do things is there ever a "right way"? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 27, 2020 Share Posted February 27, 2020 Why is it important to use a point as the pick? Quote Link to comment Share on other sites More sharing options...
ShadyV Posted March 5, 2020 Author Share Posted March 5, 2020 (if (= srt nil) (progn (command "pedit" "m" pl pl1 ar "" "y" "j" "" ""); joins all the segments! ) (command "pedit" "m" pl pl1 ar srt "" "y" "j" "" ""); joins all the segments! ) for later on Quote Link to comment Share on other sites More sharing options...
