Tirdad Posted February 25, 2020 Posted February 25, 2020 Hello there! since you're so popular I need your help. Here is my code and I need it to generate PDF only for it's job, like I have 50 pages and actually what I have here selects one page block (reads it's entity) and generates all the 50 pages, but I need to get PDF from like 25 of them not all of them! it needs to PDF ALL AT ONCE, page by page (with PDF Factory Pro Printer) Here it is : (defun c:epdf (/ ob ss bn mn mx) (vl-load-com) (setq cnt 0) (setq dir (getvar "dwgprefix")) (if (and (progn (initget "B") (setq ob (entsel "\nSelect Block/B for blockname: ")) (cond ((eq ob "B") (setq bn (getstring "\nEtner Block Name: ")) ) ((and (eq (type ob) 'LIST) (vlax-method-applicable-p (vlax-ename->vla-object (car ob)) 'getboundingbox ) ) (setq bn (cdr (assoc 2 (entget (car ob))))) ) ) ) (tblsearch "BLOCK" bn) bn (setq ss (ssget "_X" (list '(0 . "INSERT") '(410 . "Model") (cons 2 bn)) ) ) ) (progn (vla-zoomextents (vlax-get-acad-object)) (repeat (setq i (sslength ss)) (setq ML "Material-List") (setq cnt (1+ cnt)) (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'mn 'mx ) (command "plot" "yes" "model" "DWG To PDF.pc3" "ANSI A (8.50 x 11.00 Inches)" "inches" "LANDSCAPE" "no" "Window" (trans (vlax-safearray->list mn) 0 1) (trans (vlax-safearray->list mx) 0 1) "fit" "center" "yes" "monochrome.ctb" "yes" "As Displayed" (strcat dir "ML-" (itoa cnt) "-" (getvar "dwgname")) "no" "yes" "yes" "yes" ) (command ".delay" "750") ) ) (princ "\nNo Blocks Selected: ") ) (princ) ) Quote
BIGAL Posted February 26, 2020 Posted February 26, 2020 (edited) Admin needs to be moved to a new post. "Plot range of Pdf's" This does possibly what you want and Maratovich has an excellent plot routine that has lots more functions than mine. Just search here. Multi GETVALS.lspplotA3Pdfrange.lsp Edited February 26, 2020 by BIGAL Quote
SLW210 Posted February 26, 2020 Posted February 26, 2020 New thread created Plot Range of PDFs. Quote
maratovich Posted February 26, 2020 Posted February 26, 2020 Try this : Revers - Automatic batch printing Prints from Model and Layouts. It is possible to select a list of files for printing.Attach an example of your .dwg file with a title block. Then we can give recommendations. Quote
