Jaru Posted February 20, 2020 Share Posted February 20, 2020 Hello everyone in the forum, thank you in advance for the help you can give me. Ok this is the situation: I've a LISP, that calculates the slopes in a plan view or in the model, and works very well, but i need some changes adapted to this task. I'll try to explain my best. 1. Here is the code (defun c:plevel (/ decs ;|diff|; elist level osm p1 p2 slope strlevel txtelev txthgt txtpt) (setq osm (getvar 'osmode)) (while (and (or (not (setq txtelev (entsel "\nSelect Starting Level Text : "))) (not (eq "TEXT" (cdr (assoc 0 (setq elist (entget (car txtelev))))))))) (princ "\n Nothing selected or wrong object type selected, try again") ) (setq strlevel (cdr (assoc 1 elist)) decs (- (strlen strlevel) (1+ (vl-string-position 46 strlevel))) level (atof strlevel) txthgt (cdr (assoc 40 elist)) ) (initget 6) (setq slope (getreal "\n Enter Slope Like ==> 0.005 : ")) (if (not slope) (setq slope 0.005)) (setvar 'osmode 39) (setq p1 (getpoint "\nPick 1st Point: ")) ;;; (setq diff (mapcar '- (cdr (assoc 10 elist)) p1)) (while (setq p2 (getpoint "\nPick Next Point (Or Press Enter To Exit): ")) (setq level (- level (* (distance p1 p2) slope)) strlevel (rtos level decs) txtpt (getpoint "\nPick Text Place For Point Level: "); (mapcar '+ p2 diff) ) (entmake (list '(0 . "TEXT") '(100 . "AcDbEntity") '(100 . "AcDbText") (cons 10 txtpt) (cons 11 (list 0.0 0.0 0.0)) (cons 40 txthgt) (cons 1 strlevel) '(50 . 0.0) '(41 . 1.0) '(51 . 0.0) '(7 . "Standard") '(71 . 0) '(72 . 0) (cons 210 (list 0.0 0.0 1.0)) '(73 . 0)) ) (setq p1 p2) ) (setvar 'osmode osm) (princ) ) 2. Basically, what the LISP does is obtain through the slope introduced the levels at the points that the user subsequently enters. To this point, well. Ok, this is what i need 1. It does not calculate the negative slope, if the user enters a negative slope this sends an error message. calculation is not possible in that situation. I need change that to work with negative slopes. 2. that allows me, by selecting objects either line, polyline to calculate the distance first and then with the previous selection of levels, calculate the slope automatically. post the original LISP, Regards. plevel.lsp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 20, 2020 Share Posted February 20, 2020 Not sure what this breaks but comment out: (initget 6) Quote Link to comment Share on other sites More sharing options...
Jaru Posted February 21, 2020 Author Share Posted February 21, 2020 18 hours ago, ronjonp said: Not sure what this breaks but comment out: (initget 6) Hi, ronjonp neither do I, thank you for watching my post, I tell you I don't know much about programming in this of the LISP, post that because I work and it works well, but if you can modify it it would be useful in my work. Regards. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted February 21, 2020 Share Posted February 21, 2020 (edited) 21 minutes ago, Jaru said: Hi, ronjonp neither do I, thank you for watching my post, I tell you I don't know much about programming in this of the LISP, post that because I work and it works well, but if you can modify it it would be useful in my work. Regards. A comment in lisp is preceded with a semicolon so find (initget 6) in the code and replace it with ;(initget 6) or delete it. Edited February 21, 2020 by ronjonp Quote Link to comment Share on other sites More sharing options...
Jaru Posted February 24, 2020 Author Share Posted February 24, 2020 On 2/21/2020 at 10:19 AM, ronjonp said: A comment in lisp is preceded with a semicolon so find (initget 6) in the code and replace it with ;(initget 6) or delete it. thanks for the comment I tried to delete (initget 6), but I still don't change, nothing remains in the same conditions I am using it. Regards Quote Link to comment Share on other sites More sharing options...
