Ish Posted February 17, 2020 Posted February 17, 2020 Dear team, I need a lisp program to write text (chainage marking) at every vertex of polyline & 3d polyline. for more details see attach image and cad file. thanks Ch marking on polyline & 3d polyline vertex.dwg Quote
BIGAL Posted February 17, 2020 Posted February 17, 2020 Start with Chainage.lsp there are a few out there. 1 Quote
Ish Posted February 18, 2020 Author Posted February 18, 2020 6 hours ago, BIGAL said: Start with Chainage.lsp there are a few out there. SIR, I try chainage.lsp and chainage on PL.lsp, these are marking chainage at fix interval. But I need chainage at every vertex of pline and 3d polyline. As i attached image and cad file above. thanks Quote
dlanorh Posted February 18, 2020 Posted February 18, 2020 3 hours ago, Ish said: SIR, I try chainage.lsp and chainage on PL.lsp, these are marking chainage at fix interval. But I need chainage at every vertex of pline and 3d polyline. As i attached image and cad file above. thanks Try this. Not Ideal but works. (defun rh:sammlung_n (o_lst grp / tmp n_lst) (cond ( (and o_lst (zerop (rem (length o_lst) (float grp)))) (while o_lst (repeat grp (setq tmp (cons (car o_lst) tmp) o_lst (cdr o_lst))) (setq n_lst (cons (reverse tmp) n_lst) tmp nil) );end_while ) ( (not (zerop (rem (length o_lst) (float grp)))) (princ "\nModulus Error : The passed list length is not exactly divisible by the group size!!")) );end_cond (if n_lst (reverse n_lst) nil) );end_defun rh:sammlung_n (defun rh:2chge (dist acc / frp pfx str) (setq frp (rem dist 1000) pfx (fix (/ dist 1000)) ) (cond ( (= pfx 0) (setq pfx "00+")) ( (< 0 pfx 10) (setq pfx (strcat "0" (itoa pfx) "+"))) (t (setq pfx (strcat (itoa pfx) "+"))) ) (cond ( (= 0.0 frp) (setq frp "000")) ( (< 0.0 frp 10.0) (setq frp (strcat "00" (rtos frp 2 acc)))) ( (< 10.0 frp 100.0) (setq frp (strcat "0" (rtos frp 2 acc)))) (t (setq frp (rtos frp 2 acc))) ) (setq str (strcat "CH: " pfx frp " "));; adjust last blank text to shift text position left or right );end_defun (defun rh:223 (lst z / a) (setq a (reverse (cons z (reverse lst))))) (defun rh:line (spt ept) (entmakex (list '(0 . "LINE") (cons 10 spt) (cons 11 ept) (cons 8 "tick")))) (defun rh:text (ipt ht str ang) (entmakex (list '(0 . "TEXT") (cons 10 ipt) (cons 40 ht) (cons 8 "ch text") (cons 1 str) (cons 50 ang) (cons 11 ipt) '(72 . 2) '(73 . 2) ) ) ) (defun c:pvch ( / ss cnt ent typ v_lst dst txt ang tent tang tpt) (prompt "\nSelect Polylines") (setq ss (ssget '((0 . "*POLYLINE")))) (cond (ss (repeat (setq cnt (sslength ss)) (setq ent (ssname ss (setq cnt (1- cnt))) typ (cdr (assoc 70 (entget ent))) );end_setq (if (>= typ 128) (setq typ (- typ 128))) (cond ( (> typ 4) (setq v_lst (rh:sammlung_n (vlax-get (vlax-ename->vla-object ent) 'coordinates) 3))) (t (setq v_lst (rh:sammlung_n (vlax-get (vlax-ename->vla-object ent) 'coordinates) 2))) );end_cond (foreach pt v_lst (setq dst (vlax-curve-getdistatpoint ent pt) txt (rh:2chge dst 3) ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent pt))) );end_setq (rh:line (polar pt (+ ang (* pi 0.5)) 0.1) (polar pt (- ang (* pi 0.5)) 0.1)) (if (< (setq tang (- ang (* pi 0.5))) 0.0) (setq tang (+ tang pi))) (setq tent (rh:text pt (getvar 'textsize) txt tang)) (if (= (length pt) 2) (setq pt (rh:223 pt 0.0))) (if (< (* pi 0.5) tang (* pi 1.5)) (vlax-invoke (vlax-ename->vla-object tent) 'rotate pt pi)) );end_repeat );end_repeat ) );end_cond (princ) );end_defun 1 Quote
Ish Posted February 18, 2020 Author Posted February 18, 2020 Thanks Dlanorh rising star. its fulfill my requirements perfectly. Thanks again 1 Quote
