Hi Guys,
I need a Help here i have created a autolisp for insert Blocks , in this i am showing invalid layers for user
I.e block not available for that layers. But my problems is if same layer found more then one it will repeat for all same layers
i don't want to show error for every same layers. Please help me
(defun c:parkingblock(/ addblock ss acaddocument space
		        i snm lnm pos)
  (vl-load-com)
  (defun addblock (sp pos nm lname en / b)
    (setq b (vla-insertblock sp pos nm 0.1 0.1 0.1 0.0))
    (vla-put-layer b lname)
    (vla-delete en)
  (if (setq ss (ssget '((0 . "POINT"))))
      (setq acadDocument (vla-get-activedocument (vlax-get-acad-object)))
      (setq space (vla-get-modelspace acadDocument))
	(setq snm (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
	(setq lnm (vlax-get snm 'layer))
	(setq pos (vla-get-Coordinates snm))
	(cond
	  ((= lnm "P_SEM_P")
	   (addblock space pos "937" "P_SEM_P" snm))
	  ((= lnm "P_ILL_P")
	   (addblock space pos "950" "P_ILL_P" snm))
	  ((= lnm "ALB_P")
	   (addblock space pos "968" "ALB_P" snm))
	  ((= lnm "P_TEL_P")
	   (addblock space pos "980" "P_TEL_P" snm))
	  ((= lnm "ZSD_P")
	   (addblock space pos "953" "ZSD_P" snm))
	  ((= lnm "DIS_SOST")
	   (addblock space pos "926" "DIS_SOST" snm))
	  (t (princ (strcat "\nBlock not found for Layer: " lnm)));; Problem
  (princ))
Regards,
Ganesh
53 minutes ago, gS7 said:
Hi Guys,
		        i snm lnm pos)
  (vl-load-com)
    (vla-delete en)
	(cond
	  ((= lnm "P_SEM_P")
	  ((= lnm "P_ILL_P")
	  ((= lnm "ALB_P")
	  ((= lnm "P_TEL_P")
	  ((= lnm "ZSD_P")
	  ((= lnm "DIS_SOST")
  (princ))
Regards,
Ganesh
Perhaps your layer names are not all upper case!  When using the (=) function  "Defpoints" does not = "DEFPOINTS" so you should test like this
(= (strcase lnm) "P_SEM_P")
;or change this
;; to
(setq lnm (strcase (vlax-get snm 'layer)))
Edited by dlanorh
Hi Dlanorh ,
I think you did not get my point.
It will repeat same layer names like this.
If same layer for more then one i want to show them only one time to user
Example :
Block not found for Layer: P_SEG_P
Block not found for Layer: M_SEG_P
Block not found for Layer: COL_EL
Block not found for Layer: RBPA_A
You need some sort of flag list ("P_SEG_P" "yes") so if its yes don't display else change ("P_SEG_P" "No") to yes. You will need to make the list before hand of all the corresponding layers make it a defun saves lots of code in main routine and you can test separately as it will need a repeat for the length of the list. Plus a double nth or car & cadr
(("P_SEG_P" "No")("M_SEG_P" "No")(COL_…….)
Edited by BIGAL
Untested (no sample DWG) but something like this should work:
(defun c:parkingblock(/ addblock ss acaddocument space i snm lnm pos missingLyrLst)
  (vl-load-com)
    (vla-delete en)
        (cond
          ((vl-position lnm missingLyrLst)
            nil
          ((= lnm "P_SEM_P")
          ((= lnm "P_ILL_P")
          ((= lnm "ALB_P")
          ((= lnm "P_TEL_P")
          ((= lnm "ZSD_P")
          ((= lnm "DIS_SOST")
          (t
            (setq missingLyrLst (cons lnm missingLyrLst))
Thank you Bigal for your suggestion .
and Roy_043 It is working like charm thank you for your codes.
