  On 3/7/2020 at 1:47 AM, hanhphuc said:
Wow, never knew that. Thanks, new info for me.
(foreach x '( a b c d e )
(set x nil)
Expand
  Quote
(Defun a ()
.....some code
Getkword Yes/No
(Defun b ()
...more codes
Expand
Maybe this question a bit off topic but i cant figure out how to make it. "A" is done and i want and option to continue to "B" or just stop at "A" (and ends the lisp).
1. How do i do that?
2. Should i reset the vars to nil using (foreach x '(c d e) set nil at defun A or B or both?
Expand
(Defun a nil
   Some code
   (initget 1 "Yes No")
   (if (eq (getkword "\nProceed to B? [Yes/No]: ") "Yes") (b))
Edited by Jonathan Handojo
  • Thanks 1
  On 3/8/2020 at 12:39 AM, Jonathan Handojo said:
(Defun a nil
   Some code
Expand
Thanks for your reply. I assume i should set (defun b nil) right?
Expand
Whatever variables you have inside your function b, put those variables to the right of the slash. If you don't have any variables to set, then it's fine to do (defun b nil)
For example:
(Defun addtwo (a b / c) (setq c (+ a b)))
(Defun testadd nil (addtwo 4 8))
Since addtwo has a variable c, you should localize that variable. But testadd doesn't have any variables, so there's nothing to localize.
However, if you localize like
(Defun testadd ( / addtwo) (addtwo 4 8))
The function will fail because there are no functions localized within testadd
  • Thanks 1
@Jonathan Handojo,  thank you for clearing things up.
After localized ALL the setq i got:
  Quote
; error: bad argument type: numberp: nil
Expand
I assume that from localizing ALL the setq's. How to get at that line? Tried inspect but it returns CALLBACK ENTRY (which i have no idea). In Vlide i have set Break ON Error.
Edited by Sheep
Expand
That error indicates that a number is expected as an argument but nil is supplied instead. You'll have to revise your code at where the 'nil' comes from...
Or post your code here so we all can help you out.
Thanks,
Jonathan Handojo
Thanks,
Jonathan Handojo
Expand
@Jonathan Handojo, due to the company policies, i can't paste the code to public. If you don't mind, i'll paste it the in private chat.
Expand
Ok, as long as it works out.
Expand
This forum didnt allow me to send private message.
I suppose you can post the code for a moment until I download it, then edit and remove the code.
None
2 minutes of open window.
Expand
Edited by Sheep
Code remove due to company policies.
  On 3/9/2020 at 3:29 AM, Jonathan Handojo said:
Done...
Expand
Please dont paste the whole code when you'are done. My company got several people in this forum so i hope im not in trouble for breaking the rules.
I recommend you put all your sub functions under the main function. Because you did something like:
(defun A (a / b)
  (setq b (* a 5)
(defun C nil
  (+ b 9)
Since you localised b inside function A, no value is set to the variable b outside that function, therefore C will return the error you encountered.
I'd rather you do:
(defun A (a / b C d)
  (defun C (e)
    (+ e 9)
  (setq b (* a 5)
        d (C b)
P.S. I'm from Indonesia too :)
Thanks,
Jonathan Handojo
(defun A (a / b)
  (setq b (* a 5)
(defun C nil
  (+ b 9)
I'd rather you do:
  (defun C (e)
    (+ e 9)
  (setq b (* a 5)
        d (C b)
Thanks,
Jonathan Handojo
Expand
Thank you for your time. I'll try it out once i can figure out which is which. No, im not Indonesian im Malaysian. Close tho, neighbour.
Edited by Sheep
  • Funny 1
One thing worth noting is that you can also localize your functions too that lies inside a function, hence why I localized C above.
Expand
My brain hurts. 10 minutes break.
(Defun a nil
   Some code
Expand
@Jonathan Handojo, i tried above code but if select No, it does not end the LISP. But, if i select Yes, it will goto (defun Proposed) without any problem.
(defun Existing ()
...code
   (if (eq (getkword "\nProceed to Proposed? [Yes/No]: ") "Yes") (Proposed))
(defun Proposed ()
..code
