tmelancon Posted February 10, 2020 Share Posted February 10, 2020 (edited) We use PNG image files on our technicians ipads who work in the field and we have about 6-8k isometric piping drawings in each of our projects directories (multiple directories). We upload to our cloud account and they are able to access them and perform their job and mark up as needed, etc... My problem is that every year we have to generate all new PNG files to ensure the latest image of our drawings are available for them and I dread having to batch PNG using either scripting or even the Publish command because it takes so long... This may be the only way but I am seeking advice and opinions on the most efficient way to convert thousands of autocad drawings into PNG files. My current script is something line this: _.open "G:\client\division\location\area\Drawings\Example.dwg" _pngh The C:PNGH is the command we use to convert DWG to PNG and looks like this: (defun c:PNGH (/) (foreach lay (layoutlist) ;lay = each item in the layoutlist (setvar 'CTab lay) (COMMAND "-plot" "n" "" "Horizontal-PNG-Acad (Color)" "PublishToWeb PNG.pc3" "" "n" "Y") ); end of foreach function (command "CTAB" "MODEL" "ZOOM" "ALL" "_QSAVE" "_CLOSE") (PRIN1)) On average it takes about 3-4 seconds per drawing to be converted while running the batch. Is there a better more efficient way (meaning the accore method so I dont have to use multiple workstations) I am currently looking at about 22,000 drawings in front of me. I am about 4,000 in. Open to discussion... THANKS SO MUCH IN ADVANCE! Edited February 13, 2020 by tmelancon wanted to clarify it wasnt that 3-4 seconds was too slow... but... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 11, 2020 Share Posted February 11, 2020 (edited) Maybe try Accoreconsole.exe this allows you to script multiple dwgs and do something with them including running a lisp it does not open the dwg so it will work in background. Do a search here for examples I have used it as a test some people use it all the time. Not sure how much faster it will work but a big time component is open dwg and close again. This is for one dwg there are some do a directory via a bat file so would make it easier again, will try to find the bat example. cd\ cd c:\Program files\Autodesk\Autocad 2020 accoreconsole.exe /i d:\alan\test.dwg /s d:\alan\lisp\test.scr Edited February 11, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 11, 2020 Share Posted February 11, 2020 Just one I found https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/accoreconsole-batch/td-p/8487768 Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 12, 2020 Author Share Posted February 12, 2020 BigAL Thank you so much for taking time to respond to my request. I have checked out the link and ended up using this one... echo off :: Path to AutoCAD core console set accoreexe="C:\Program Files\Autodesk\AutoCAD 2019\accoreconsole.exe" :: Path the directory to process set "source=C:\Drawings\test\testscr" :: Path to the script to run set script="C:\Drawings\test\pasteblock.scr" FOR /f "delims=" %%f IN ('dir /b "%source%\*.dwg"') DO %accoreexe% /i "%source%\%%f" /s %script% :: comment the following to automatically close the console when batch ends pause Now the problem is when I use C:PNGH which is that little custom written command you can refer to in first post, it says: Unknown Command "PNGH". Press F1 for Help! Command: _quit I re-wrote the script just to test and see and it looks like this: CTAB QSAVE CLOSE ...and it executed perfectly on all 5 test drawings. Any reason why I am getting that error when I run PNGH from the script? I am so close... Any ideas? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 12, 2020 Author Share Posted February 12, 2020 Ok so I have update and tested multiple times, here is my latest and although is not giving me errors anymore, it just simply runs through then nothing happens afterwards. No PNGs, nothing. Just runs then finishes with no visible results. .BAT FOR /R %%f IN (*.dwg) DO "C:\Program Files\Autodesk\AutoCAD 2014\AcCoreConsole.exe" /i "%%f" /s "C:\Users\tmelancon\Desktop\TEMP-ATL-BATCH-IPAD\TESTER\TESTER2.scr" /l en-US .SCR (load "C:\Users\tmelancon\Desktop\TEMP-ATL-BATCH-IPAD\TESTER\TESTER.lsp") (C:PNGH2) .LSP (defun c:PNGH2 (/) (foreach lay (layoutlist) ;lay = each item in the layoutlist (setvar 'CTab lay) (COMMAND "-plot" "n" "" "Horizontal-PNG-Acad (Color)" "PublishToWeb PNG.pc3" "" "n" "Y") ); end of foreach function (command "CTAB" "MODEL" "ZOOM" "ALL") (PRIN1)) Still trying. I have about 7k drawings processed so far via dragging ascript like this into my CAD window: _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example1.dwg" _pngh _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example2.dwg" _pngh _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example3.dwg" _pngh _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example4.dwg" _pngh _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example5.dwg" _pngh _.open "C:\Users\[USERNAME]\Desktop\Drawings\Example6.dwg" _pngh The problem with that is it physically opens each drawing, performs the command, closes out, then moves on to the next one. VERY VERY tidious... averages 3-4 seconds for a one page drawing... I have about over 20k to process and there could potentially be more afterwards. This is just a start. I feel like I am getting closer. Quote Link to comment Share on other sites More sharing options...
maratovich Posted February 12, 2020 Share Posted February 12, 2020 Give us an example of your .dwg file. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 12, 2020 Share Posted February 12, 2020 Why not just have them use the drawings? Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 12, 2020 Author Share Posted February 12, 2020 SLW210, at this moment, an image file is what is compatible with our 3rd party software. Works wonders. These PNG files are used in more places than one and for more than one use. I gave you a single example. Its a requirement. Thank you for your input though. Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 12, 2020 Author Share Posted February 12, 2020 Our drawings are basically 8x11 canvas, we draw in model space, we then have a layout for each page of our drawing (i.e. 4 pages then Drawing1, Drawing2, Drawing3, Drawing4). Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 12, 2020 Share Posted February 12, 2020 (edited) The problem may be in the line (foreach lay (layoutlist) As a 1st test try using this it is not tested. This will show if (layoutlist) is the problem. (setq lays (layoutlist)) (repeat (setq x (length lays)) (setvar 'ctab (nth (setq x (- x 1)) lays)) (COMMAND "-plot" "n" "" "Horizontal-PNG-Acad (Color)" "PublishToWeb PNG.pc3" "" "n" "Y") ); end of foreach function (command "CTAB" "MODEL" "ZOOM" "ALL") ) Edited February 12, 2020 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 13, 2020 Share Posted February 13, 2020 3 to 4 seconds per drawing seems very fast to me. I would just see about setting it up on a separate machine and let it run until done. If not then a more robust machine to get the time down maybe. It would be instant if you had it set up for them to use the drawings. There are some apps for iPads and CAD viewing/markup. 1 Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 13, 2020 Author Share Posted February 13, 2020 BIG AL, The batch isnt working but I tested your code on a standalone drawing and it works very similar to mine except it does it in reverse order (i.e. my foreach prints pg1, pg2, etc.. yours prints pg4, p3, p2, p1...) SLW210 you are right, this time isn't that bad, I just know the accore.exe way would definitely bring it down to 2 secs each and I would also be able to still use CAD. I may just have to seek out a second rig around here to put this task on. Thanks for that opinion. We use these PNG files for all sorts of things, we use them for review, we are constantly emailing and marking up on them, clients view them (and they do not have CAD and do not want CAD lol), they just want to open it up see our revision really quick and move along. Thanks for that input though. I will continue to roll my old school way and test other methods periodically through the day. If I could figure it out man that would be nice! Thanks for all of your help! Talk to you soon! Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 13, 2020 Author Share Posted February 13, 2020 Im convinced it's my LISP for some reason. Something about having to step into "each" layout or something idk... I ran a batch by changing the script to something basic like: <Start Script> CTAB Drawing1 QSAVE CLOSE <End Script> ...and when I opened each drawing they were all updated and I used the same code using accoreexe... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 14, 2020 Share Posted February 14, 2020 (setq lays (reverse (layoutlist))) fixes backward plot order. What happens with 1 dwg in a test script using repeat of the code above. Don't do the batch looping echo off :: Path to AutoCAD core console set accoreexe="C:\Program Files\Autodesk\AutoCAD 2019\accoreconsole.exe" :: Path the directory to process set "source=C:\Drawings\test\testscr\dwgname" :: Path to the script to run set script="C:\Drawings\test\pastetest.scr" %accoreexe% /i "%source%" /s %script% Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 14, 2020 Author Share Posted February 14, 2020 BIGAL! Thanks again for your remarkable advice and assistance with all of this! I truly can't thank you enough. Im determined to get this. So after further testing, it appears that my LISP is somehow the culprit. I even tested the LISP without the (foreach lay (layoutlist) and without the (repeat (setq x (length lays) and it still didnt work. ----TEST #1---- .BAT: echo off echo Starting AcCoreConsole c: cd C:\Users\[USERNAME]\Desktop\IPAD\TESTER echo ================================================================================ FOR %%f in ("C:\Users\[USERNAME]\Desktop\IPAD\TESTER\*.dwg") DO "C:\Program Files\Autodesk\AutoCAD 2014\AcCoreConsole.exe" /i "%%f" /s "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TESTER2 - Copy.scr" /l en-US echo Done! pause SCRIPT: ctab drawing1 -plot n drawing1 Horizontal-PNG-Acad (Color) PublishToWeb PNG.pc3 n y ctab model It generates a PNG for all 5 drawings in the folder without a single issue, and it did it FAST, like 2-3 seconds for ALL FIVE! Keep in mind by doing it this way, it ONLY creates PNG of first layout Drawing1 and thats it. My LISP generates Drawing1 then cycles through the additional layouts if there are any. That is really what I need this to do in order to work. ----TEST #2---- Here is what I tried to do to bring it back to the basics for Drawing1 ONLY, not even going into multiple layouts, just 1, to keep it simple during testing: .BAT: echo off echo Starting AcCoreConsole c: cd C:\Users\[USERNAME]\Desktop\IPAD\TESTER echo ================================================================================ FOR %%f in ("C:\Users\[USERNAME]\Desktop\IPAD\TESTER\*.dwg") DO "C:\Program Files\Autodesk\AutoCAD 2014\AcCoreConsole.exe" /i "%%f" /s "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TESTER2.scr" /l en-US echo Done! pause SCRIPT: <Start Script> (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TESTER - Copy.LSP") (C:PNGH3) <End Script> LISP: (defun C:PNGH3 (/) (COMMAND "CTAB" "DRAWING1") (COMMAND "-plot" "n" "" "Horizontal-PNG-Acad (Color)" "PublishToWeb PNG.pc3" "" "n" "Y") (command "CTAB" "MODEL" "ZOOM" "ALL") );end defun Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 14, 2020 Share Posted February 14, 2020 (edited) Had another look and may have an idea when you do -plot and "N" it expects Horizontal-PNG-Acad (Color) is set in the plot if this is missing lisp will error try plotting with a full -plot "Y" Something like this is a full version you can use extents and fit for the png (COMMAND "-PLOT" "Y" "" "DWG To PDF" "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "Acad.ctb" "Y" "n" "n" "n" pdfName "N" "y" ) Whilst your testing on a dwg that has the sheet set your lisp will work. (setvar 'ctab lay) Edited February 14, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 17, 2020 Author Share Posted February 17, 2020 (edited) Hey BIGAL thanks again for your continued efforts. I updated the plot routine to use detailed plot configuration. Everything runs normally with no errors or visible issues however I see no PNGs as a results to running the test on the five sample drawings I performed the batch on. The batch opens, runs through the script, but I see no PNGs in my test folder where my drawings are at. It also appears it is running the code through CMD Prompt and not accoreconsole.exe... I though it would open and execute code from here... This is my first time exploring accoreconsole so maybe that is normal..Not sure how to get it to run out of accoreconsole. Still a work in progress... With everything I currently am working with, regardless of whether I test as batch or test with individual drawing, it just does the following with no actual results: Command: (load "C:\\........) Command: PNGH2 Command: Command: _quit Edited February 17, 2020 by tmelancon Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 17, 2020 Share Posted February 17, 2020 (edited) This should work save as a bat file echo off :: Path to AutoCAD core console set accoreexe="C:\Program Files\Autodesk\AutoCAD 2019\accoreconsole.exe" :: Path to the script to run set script="C:\Drawings\test\pastetest.scr" %accoreexe% /i C:\Drawings\test\testscr\dwg1 /s %script% %accoreexe% /i C:\Drawings\test\testscr\dwg2 /s %script% %accoreexe% /i C:\Drawings\test\testscr\dwg3 /s %script% %accoreexe% /i C:\Drawings\test\testscr\dwg4 /s %script% look into a couple of things to write a bat CMD cd C:\Drawings\test\testscr\ Dir *.dwg /s /b >dwgnames.txt This should make a text file of all the dwg's in the directory plus any below sub directorys. Then use word you can replace ^p which is end of line with ^p"C:\Program Files\Autodesk\AutoCAD 2019\accoreconsole.exe" and do same for ends "C:\Drawings\test\pastetest.scr"^p or excel use concatenate to join the columns =concatenate(a1," ",b1," "c1) to make the bat file. Edited February 17, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
tmelancon Posted February 18, 2020 Author Share Posted February 18, 2020 Hey BIGAL, I have developed a spreadsheet with macros and some VBA that allows me to list out a drawing directory, extract the drawing name with and without the .dwg extension depending on which one I need so I can use it for specific tasks. However, you provided me with another useful method to use as an alternative and I appreciate that. It is always good to learn new things. Quote Dir *.dwg /s /b >dwgnames.txt As far as the BAT file, I have created one identically to what you specified and edited to my directory and samples file names and again it is running through each one like it is performing successfully, but again no PNGs.. [CMD Results] C:\Users\[USERNAME]\Desktop\IPAD\TESTER>echo off AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013. Regenerating model. Command: Command: Command: Command: Command: (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") Command: PNGH3 Command: Command: _quit AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013. Regenerating model. Command: Command: Command: Command: Command: (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") Command: PNGH3 Command: Command: _quit AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013. Regenerating model. Command: Command: Command: Command: Command: (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") Command: PNGH3 Command: Command: _quit AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013. Loading Modeler DLLs. Regenerating model. Command: Command: Command: Command: Command: (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") Command: PNGH3 Command: Command: _quit AutoCAD Core Engine Console - Copyright Autodesk, Inc 2009-2013. Loading Modeler DLLs. Grid too dense to display Regenerating model. Grid too dense to display Command: Command: Command: Command: Command: (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") Command: PNGH3 Command: Command: _quit Press any key to continue . . . [BAT] echo off :: Path to AutoCAD core console set accoreexe="C:\Program Files\Autodesk\AutoCAD 2014\accoreconsole.exe" :: Path to the script to run set script="C:\Users\[USERNAME]\Desktop\IPAD\TESTER\tester2.scr" %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST1.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST2.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST3.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST4.dwg /s %script% %accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST5.dwg /s %script% pause [SCRIPT] <Start Script> (load "C:\Users\[USERNAME]\Desktop\IPAD\TESTER\\TESTER.LSP") PNGH3 <End Script> [LISP] (defun c:pngh3 (/ lays x) (setq lays (reverse (layoutlist))) (repeat (setq x (length lays)) (setvar 'ctab (nth (setq x (- x 1)) lays)) (COMMAND "-plot" "Y" "" "PublishToWeb PNG.pc3" "Sun hi-Res (1600.00 x 1280.00 Pixels)" "L" "N" "EXTENTS" "F" "C" "Y" "ACAD.CTB" "Y" "N" "Y" "N" "" "N" "Y") ); end of repeat function (command "CTAB" "MODEL" "ZOOM" "ALL" "QSAVE" "CLOSE") (PRIN1)) I am so confused as to why it wouldn't work and I don't know enough about accoreconsole to know if the lisp is the culprit. When I test the lisp in CAD it works. When I open an individual drawing and drag my TESTER2.scr in the drawing, it processes the script as usual, loads the lisp, runs C:PNGH3, saves, closes, and my PNG appears. However, its when I introduce the LISP is when it just runs with no errors and doesn't produce the resulted PNG. Sorry for the lengthy posts I just want to provide whoever reads the post, yourself included, enough information for advice to be provided. Is there a way you can sort of use what I have and create your own directory on your desktop with 5 test drawings, each drawing with +1 Layout so we can process multi-page drawings with the test? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 18, 2020 Share Posted February 18, 2020 (edited) https://houseofbim.com/2016/10/05/son-of-a-batch-autocad-core-console-through-lisp/ May have found it you have no png filename "ACAD.CTB" "Y" "N" "Y" "N" "" "N" by going accept it gets nothing so your lisp needs to add a filename like dwgname-ctab my plot pdf Acad.ctb" "Y" "n" "n" "n" pdfName "N" "y" Edited February 18, 2020 by BIGAL Quote Link to comment Share on other sites More sharing options...
