sudam Posted February 10, 2020 Posted February 10, 2020 Hi friends i m new in lisp. i have regularly required cross section profile for mines activity. any one can help me for cross section or 3d line profile. pls pls pls help me . for more details i had attached my file. pls pls pls help me. Cross section.dwg Quote
BIGAL Posted February 11, 2020 Posted February 11, 2020 (edited) This was CIV3D and Civil site design, 100m wide cross section 6 minutes and some 40 cross sections produced. just a case of changing some limits etc could be to full limit of surface. If you have Briscad or Autocad then www.civilsurveysolutions.com.au will do so much more. But yes at a price. Edited February 11, 2020 by BIGAL Quote
Roy_043 Posted February 12, 2020 Posted February 12, 2020 Here is a basic solution: (defun KGA_List_LastRemove (lst) (reverse (cdr (reverse lst))) ) (defun c:CreateCrossSection ( / doc end enm fac lin lst ss sta vec) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (setvar 'cmdecho 0) (if (and (= 1 (getvar 'worlducs)) (equal '(0.0 0.0 1.0) (getvar 'viewdir)) (setq lin (car (entsel "\nSelect line for cross section: "))) (setq vec (getpoint "\nInsertion point for section: ")) (setq fac (getreal "\nHeight factor: ")) (progn (command "_.zoom" "_object" lin "") T) (setq lin (entget lin)) (= "LINE" (cdr (assoc 0 lin))) (setq sta (KGA_List_LastRemove (cdr (assoc 10 lin)))) (setq end (KGA_List_LastRemove (cdr (assoc 11 lin)))) (setq ss (ssget "_F" (list sta end) '((0 . "POLYLINE") (-4 . "&=") (70 . 8)))) (progn (command "_.zoom" "_previous") T) ) (progn (setq lst (vl-remove nil (mapcar '(lambda (itm) (if (and (listp itm) (= 0 (car itm))) (list (distance sta (KGA_List_LastRemove (cadr itm))) (caddr (cadr itm))) ) ) (apply 'append (ssnamex ss)) ) ) ) ;; Sort points: (setq lst (vl-sort lst '(lambda (a b) (< (car a) (car b))) ) ) ;; Remove duplicate points: (setq lst (vl-remove nil (mapcar '(lambda (cur prev) (if (equal cur prev 1e-8) nil cur) ) lst (cons nil lst) ) ) ) ;; Calculate point for LW poly: (setq vec (mapcar '* '(1.0 1.0 0.0) vec)) (setq lst (mapcar '(lambda (pt) (list (+ (car pt) (car vec)) (+ (* fac (cadr pt)) (cadr vec))) ) lst ) ) ;; Create LW poly: (vlax-invoke (vla-get-modelspace doc) 'addlightweightpolyline (apply 'append lst)) ;; Create base line: (vlax-invoke (vla-get-modelspace doc) 'addline vec (mapcar '+ vec (list (distance sta end) 0.0 0.0))) (command "_.zoom" "_extents") ) ) (setvar 'cmdecho 1) (vla-endundomark doc) (princ) ) Quote
marko_ribar Posted February 12, 2020 Posted February 12, 2020 (edited) Roy, your code is probably fine in BricsCAD, but when I test it under A2018, my (ssnamex ss) is returning wrong Z coordinate of ssget-fence intersection points... I don't know if this is the case and with others who have A2018 (I recently reinstalled it, so maybe that process bugged my CAD), but nevertheless I found solution to this particular case... I changed this : (setq lst (vl-remove nil (mapcar '(lambda (itm) (if (and (listp itm) (= 0 (car itm))) (list (distance sta (KGA_List_LastRemove (cadr itm))) (caddr (cadr itm))) ) ) (apply 'append (ssnamex ss)) ) ) ) To this : (setq lst (vl-remove nil (mapcar '(lambda (itm) (if (and (listp itm) (= 0 (car itm))) (list (distance sta (KGA_List_LastRemove (cadr itm))) (caddr (vlax-curve-getclosestpointtoprojection (vl-some '(lambda (x) (if (= (type x) 'ename) x)) (vl-member-if '(lambda (x) (equal x itm)) (reverse (apply 'append (ssnamex ss))))) (KGA_List_LastRemove (cadr itm)) '(0.0 0.0 1.0)))) ) ) (apply 'append (ssnamex ss)) ) ) ) And it seems that this mod. fixed the problem... I only don't know why is now my CAD buggy... Can someone verify this issue with OP's posted DWG and AutoCAD testing? Does someone had this problem and was the solution found? (z coordinates are always with the same value although it's obvious that they should differ...) Thanks for your input, M.R. Edited February 12, 2020 by marko_ribar Quote
BIGAL Posted February 12, 2020 Posted February 12, 2020 (edited) I did respond as its a CIVIL Engineering question, so the freebie answer is here at Cadtutor its a triangulation solution by YMG just search I think it has had cross sections added. There are some others out there also just google Triangulation & Lisp. I have been involved in this type of thing since Green screen PC's. Roy_043 I would not spend the time it is reinventing the wheel. I produced 40 sheets with 3 cross sections per sheet it takes about 15 seconds to change parameters like Hor and Ver scales and a regen reproduces the sheets. The dwg provided appears to have been produced in CIV3D so why not cross sections produced ? It would have been far more accurate to have started with a triangulation which probably exists but was not in dwg. . Edited February 12, 2020 by BIGAL Quote
Roy_043 Posted February 13, 2020 Posted February 13, 2020 @marko_ribar Thanks for looking at my code. The original code indeed works in BricsCAD (V18). I typically test my code before posting. Quote
Guest Posted March 22, 2020 Posted March 22, 2020 Hi marco nice code. can you update the code to write the elevetion and the distance through specific point . For example i have my center line with the name layer name "axon" and my cross section lines with the layer name "sections". want to select first the layer "axon" (the zero length mast be on axon and at the left we ha (- length) and for the right (+ length)) and second select all the sections and create all the sections in al list with section numbers d1,d2,d3,d4 ...... Thanks test.dwg Quote
pmadhwal7 Posted March 23, 2020 Posted March 23, 2020 may be this lsp help u... long_section_3dp.lsp Quote
Guest Posted March 23, 2020 Posted March 23, 2020 (edited) hi pmadhwal7 . No this lisp dont help me. I need samething for cross sections no long sections. Something to export this Edited March 23, 2020 by prodromosm Quote
pmadhwal7 Posted March 24, 2020 Posted March 24, 2020 13 hours ago, prodromosm said: hi pmadhwal7 . No this lisp dont help me. I need samething for cross sections no long sections. Something to export this u can draw cross section too with help of this lsp.... Quote
Guest Posted March 24, 2020 Posted March 24, 2020 No you don't. The 0 is not all the time in the midle. You have to select the aligment line and then the section .So you sure that the 0 is in the corect place. In some times you will a cross section from -20 to +40 Quote
BIGAL Posted March 25, 2020 Posted March 25, 2020 In what I used you set limits can be as you want -20 +40 its based around an alignment line its always the 0 line. Quote
