brandalf_the_semiGray Posted February 3, 2020 Posted February 3, 2020 Trying to extract a name I generate and add to a list for use in the ssget function. I keep getting bad point pair errors. Below is the offending line (setq blks (ssget "x" (cons 2 (nth i nm)))) This is what's in the nth item. Below is the code i use to append an item into the list i'm trying to access in the ssget function (setq names (append names (list (read (strcat partNum "_" (nth (atoi (nth (setq index (1+ index)) dimension)) (cadr (nth 1 data)))))))) Ideas? I've tried everything from strcat, to using (assoc "names" (nth i nm)) in my ssget call. Pretty stuck here. Quote
brandalf_the_semiGray Posted February 3, 2020 Author Posted February 3, 2020 (edited) So i realized it was a symbol, so i've used vl-symbol-name to retrieve the string name, but i'm still unable to send the (cons 2 (vl-symbol-name (nth i nm))) argument to the ssget function. I still get a bad point argument error. Please help. Edited February 3, 2020 by brandalf_the_semiGray Quote
dlanorh Posted February 3, 2020 Posted February 3, 2020 (edited) 1 hour ago, brandalf_the_semiGray said: Trying to extract a name I generate and add to a list for use in the ssget function. I keep getting bad point pair errors. Below is the offending line (setq blks (ssget "x" (cons 2 (nth i nm)))) This is what's in the nth item. Below is the code i use to append an item into the list i'm trying to access in the ssget function (setq names (append names (list (read (strcat partNum "_" (nth (atoi (nth (setq index (1+ index)) dimension)) (cadr (nth 1 data)))))))) Ideas? I've tried everything from strcat, to using (assoc "names" (nth i nm)) in my ssget call. Pretty stuck here. Only blocks have names. If you want to ssget all blocks with a certain name the filter needs to be in the format : (ssget "x" (list '(0 . "INSERT") (cons 2 blkname))) Where blkname is a string of block names separated with comma(s). What type of entity is SYM ? Edited February 3, 2020 by dlanorh Quote
ronjonp Posted February 3, 2020 Posted February 3, 2020 1 hour ago, brandalf_the_semiGray said: Trying to extract a name I generate and add to a list for use in the ssget function. I keep getting bad point pair errors. Below is the offending line (setq blks (ssget "x" (cons 2 (nth i nm)))) ... Quick glance: ;; This (setq blks (ssget "_X" (cons 2 (nth i nm)))) ;; Should be this (setq blks (ssget "_X" (list (cons 2 (nth i nm))))) Quote
brandalf_the_semiGray Posted February 3, 2020 Author Posted February 3, 2020 oh man. that did it. thanks guys. I was reading the documentation for ssget and didn't catch that it needed to recieve a list for some reason Quote
