Ribbon set to vertical
Dayananda
Probably (it can in 2018/19/20) right click on an empty part of the bar across the top of the ribbon where all the tabs are (Home-Insert-Annotate-etc.) and click undock, now go to the ribbon (wherever it appears) and right click on it's title bar again in an empty spot (the bar that says 'ribbon' ) make sure there is a check mark/tick next to allow docking then choose anchor left or right.
  • Thanks 1
