Which system variable control the way to select  more than one entity by pick  with cursor.
If I  want to copy , from the tool bar menu,  it select the first , but when I select the second , it remove the first and select only the second.
Quote
Command: _copy
Select objects: 1 found
Select objects: 1 found, 1 total
Select objects: *Cancel*
If I select by Cross,  it select both
Quote
Command:
Command: _copy
Select objects: Specify opposite corner: 2 found
Select objects:
Current settings:  Copy mode = Multiple
Right_click -> Options ->Tap Selection -> Use shift to add selection.
If you still want to know the name of the system variable it is PICKADD.
  • Thanks 1
