Bill Tillman Posted January 22, 2020 Posted January 22, 2020 I have an issue with the HATCH command. When I draw a rectangle, for example and then fill it with a hatch, the end result is that I have the hatch but it now includes the lines which formed the boundary of it. So if I erase it or move it, the whole mess moves or gets erased. I've tried looking for a setting for this but can't seem to find anything that resolves the issue. Quote
Bill Tillman Posted January 22, 2020 Author Posted January 22, 2020 Okay, found the issue. The hatch settings were set to Associative. That fixed it. 1 Quote
steven-g Posted January 22, 2020 Posted January 22, 2020 Just so you know, setting a hatch to be associative means that you can stretch or otherwise deform the original outline and the hatch will expand automatically to fill the new outline, this can be really usefull. Also when you move objects the hatch goes with it. Non associative hatching doesn't do this an is a stand alone feature. Quote
Bill Tillman Posted January 23, 2020 Author Posted January 23, 2020 Thank steven-g. That's useful information. Quote
SLW210 Posted January 23, 2020 Posted January 23, 2020 Unless things have changed, you should be able to delete the Hatch without deleting the original boundary and delete the boundary without deleting the hatch, it is sometimes hard to select just the boundary, but possible. Quote
