Converting User Profiles from AutoCAD.arg to BricsCAD.arg
I am an older user of AutoCAD and I am a newbie with BricsCAD.
I am after assistance &/or help with conversion of my latest AutoCAD.arg to a BricsCAD.arg equivalent.
I have read that BricsCAD is able to import user profile settings from a *.csv file but I don't think that AutoCAD can export user profile information to this *.csv file format.
Thanks in advance
Kim WILLIAMS
You can run a lisp that will probably do the same as adding a profile. Have a look at this. We then had a script that loaded each users preferred tool bars. It has the trustedpaths in it as well. I had Menuload in it as well but needed to revisit that part so its not there.
set paths 2018.lsp
