mruu Posted January 10, 2020 Posted January 10, 2020 I've been using the block replace from here. Quick question: ... (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*)) (setq temp (vla-copy blk)) (mapcar (function (lambda (p) (vl-catch-all-apply (function vlax-put-property) (list temp p (vlax-get-property x p)) ) ) ) '(Insertionpoint Rotation) ;something like "Attributes" or "REF" in here..?? ) (vla-delete x) ) ... If I wanted to keep the attributes of the original blocks (as well as their "InsertionPoint" & "Rotation"), is there a word like "Attributes" or something i can slide in to do so? Cheers. Quote
Aftertouch Posted January 10, 2020 Posted January 10, 2020 (edited) This is the code that i use. ;; [oldblk] = old block entity name ;; [newblk] = new block name ;; [blkloc] = block location list of x y z ;; [blklayer] = string of layername (defun HB:BLOCKREPLACE (oldblk newblk blkloc blklayer / ) (command "-INSERT" newblk blkloc "" "" "") (vlax-put-property (vlax-ename->vla-object (entlast)) 'Layer blklayer) (LM:setattributevalues (entlast) (LM:getattributevalues oldblk)) (vla-erase (vlax-ename->vla-object oldblk)) ) Code profided by LeeMac: ;; blk - [ent] Block (Insert) Entity Name ;; Returns: [lst] Association list of ((<tag> . <value>) ... ) (defun LM:getattributevalues ( blk / enx ) (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))) (cons (cons (cdr (assoc 2 enx)) (cdr (assoc 1 (reverse enx))) ) (LM:getattributevalues blk) ) ) ) Code profided by LeeMac: ;; blk - [ent] Block (Insert) Entity Name ;; lst - [lst] Association list of ((<tag> . <value>) ... ) ;; Returns: nil (defun LM:setattributevalues ( blk lst / enx itm ) (if (and (setq blk (entnext blk)) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget blk)))))) (if (setq itm (assoc (cdr (assoc 2 enx)) lst)) (progn (if (entmod (subst (cons 1 (cdr itm)) (assoc 1 (reverse enx)) enx)) (entupd blk) ) (LM:setattributevalues blk lst) ) (LM:setattributevalues blk lst) ) ) ) Edited January 10, 2020 by Aftertouch Quote
ronjonp Posted January 10, 2020 Posted January 10, 2020 Try something like this .. no error checking. (defun _matchatts (b1 b2 / a) (setq a (vlax-vla-object->ename b2)) (foreach x (vlax-invoke b1 'getattributes) (setpropertyvalue a (vla-get-tagstring x) (vla-get-textstring x)) ) ) (vlax-for x (setq ss (vla-get-activeselectionset *acaddoc*)) (setq temp (vla-copy blk)) (mapcar (function (lambda (p) (vl-catch-all-apply (function vlax-put-property) (list temp p (vlax-get-property x p))) ) ) '(insertionpoint rotation) ;something like "Attributes" or "REF" in here..?? ) (_matchatts x temp) (vla-delete x) ) 1 Quote
mruu Posted January 20, 2020 Author Posted January 20, 2020 Thanks for that guys, appreciate the input. Aftertouch, your code doesn't allow old & new block names to be equal. That is a problem for me. Ronjonp, your code works perfectly. If I ever want to go back to replacing the old with new attributes I can simply deactivate the "(_matchatts x temp)" line as well which is handy. Thanks so much!! Quote
ronjonp Posted January 20, 2020 Posted January 20, 2020 12 hours ago, mruu said: Thanks for that guys, appreciate the input. Aftertouch, your code doesn't allow old & new block names to be equal. That is a problem for me. Ronjonp, your code works perfectly. If I ever want to go back to replacing the old with new attributes I can simply deactivate the "(_matchatts x temp)" line as well which is handy. Thanks so much!! You're welcome! Quote
