IF / THEN .... Maybe ?
I have a block that is used all the time & it needs to show text w/ an "HD" when another certain attribute is larger than 9, but not show when its less than 9.  I've looked at diesel & a field but reading up they seem not to work well together.  All help would be much appreciated.
Thanks
Joey G
Joey G ,
I have not understand well what do you mean with "...show text w/ an "HD" when another certain attribute is larger than 9 ..." please could you explain where do you want to show the text ? inside the block ? modifying another attribute ?
Example ??
Of course with VBA you can select blocks, attributes, manipulate it, and so on.
Thank you
