CJG Posted January 8, 2020 Share Posted January 8, 2020 Hi, is there a way to change the line width of the text frame when the 'Text frame' option is changed to 'Yes'? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 8, 2020 Share Posted January 8, 2020 Not any that I know of. Try using TCIRCLE (Should be an Express Tool), it places an editable PLINE around Text or MText. 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted January 8, 2020 Share Posted January 8, 2020 If you turn on lineweight visibility and change the lineweight for the layer, you will see the frame width change. The lineweight of the leader also changes, so that may be a deal breaker. 1 Quote Link to comment Share on other sites More sharing options...
CJG Posted January 9, 2020 Author Share Posted January 9, 2020 21 hours ago, SLW210 said: Not any that I know of. Try using TCIRCLE (Should be an Express Tool), it places an editable PLINE around Text or MText. Thanks SLW210. I was after something that would then change when the text is added to or shortened. This is a good option if all else fails. Quote Link to comment Share on other sites More sharing options...
CJG Posted January 9, 2020 Author Share Posted January 9, 2020 18 hours ago, CyberAngel said: If you turn on lineweight visibility and change the lineweight for the layer, you will see the frame width change. The lineweight of the leader also changes, so that may be a deal breaker. Thanks CyberAngel. This could be a workable solution and I will create another layer for the leaders with a different lineweight. Quote Link to comment Share on other sites More sharing options...
