align block with text
pmadhwal7
You get no help then need to do it by yourself.
suggestion: in Layout (paper space) make sure layout name is numerical.
1. Insert your arrow block eg: layout 01
2. make 2 field objects
command: FIELD
in Field category -> All -> Formula
copy this expression
Quote
%<\AcVar ctab>%-1
%<\AcVar ctab>%+1
to formula space
3. evaluate and insert 'field-text' in layout
4. manually align 'field text' with the arrow block
5. Select aligned arrows blocks & texts, Copy <Crtl^C>  then paste to others layout eg: 02, 03, 04 etc..
   the 'sheet No: ###' it will be updated automatically according to layout name
Edited by hanhphuc
command: FIELD
to formula space
sir i tried this method but not able to use can u create a video for me
well, i think field-attributed block is better than align MTEXT as mentioned in my previous post
$0.02 making a drawing faster than making a video !!
download this example
sheet no.dwg
 In layout 01 you will see this 2 blocks
Sheet No: 00            Sheet No: 02
simply copy both blocks from layout 01 & paste it to other layout 02, 03, etc..
command: regen
not working on model space
command: regen
Edited by Roy_043
  • Thanks 1
In a different way model is numeric if you look at taborder Model is always 0.
Same as you can have layouts with any name and number suffix but sheet number will be correct using taborder value ie the order you have arranged them in.
Recent post.
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(setq x '())
(vlax-for lay (vla-get-Layouts doc)
(setq x  (cons (strcat (vla-get-name lay) " " (rtos (vla-get-taborder lay) 2 0)) x))
("Model 0" "Layout2 2" "Layout1 1")
Edited by BIGAL
15 hours ago, pmadhwal7 said:
please check my sample dwg
if you insist using in model space, then my previous solution won't work!
stop making things complicated,
1. either use 'sheet no.dwg' as templete (copy 'arrow.dwg' then pasteorig to 'sheet no.dwg 'model )or..
2. copy field-attributed-arrow from 'sheet no.dwg' to you 'sample arrow.dwg's LAYOUT / paper space NOTin Model space!!!
3. try learing your own arrow LISP routine which satisfying your requirement :)
actually sir it should shown in model space like my arrow and sheet number but when i am working with ur method sheet number is not showing that's y i also attached my lsp which only give me sheet number not arrow and rotating arrow and arranging them taking lots of time
Recent post.
(setq x '())
sir...can u explain it how to use this?
Redid it to make more useable the list produced is the layout name and the order number of the layout
(setq lst '())
(setq lst  (cons (list (vla-get-name lay) (vla-get-taborder lay)) lst))
(("Model" 0) ("Layout2" 2) ("Layout1" 1)) just use nth etc of a list
Edited by BIGAL
  • Confused 1
@BIGAL
FWIW you don't need to create an empty list when using CONS.
(setq lst '())
Edited by ronjonp
  • Confused 1
Ronjonp your right, just a habit making sure have not used elsewhere or in a repeat etc. Some one else's code may have used lst, ss is pretty common for selection set as an example.
