Speedster2 Posted January 2, 2020 Posted January 2, 2020 I have modified a lips that join words and forms a text. That was successful. But the original position of the words not deleted. Please help. I have attachment the lisp and sample dwg texts join.lsp Drawing1.dwg Quote
SLW210 Posted January 2, 2020 Posted January 2, 2020 I have moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the correct forum. Quote
marko_ribar Posted January 2, 2020 Posted January 2, 2020 Have you tried to replace this : (while (= count slen) (entdel sget) (setq count (1- count)) ) With this : (acet-ss-entdel sset) Regards... 1 Quote
Roy_043 Posted January 3, 2020 Posted January 3, 2020 Marko has identified the piece of code that causes the problem. The (= count slen) condition is true only once. 1 Quote
BIGAL Posted January 4, 2020 Posted January 4, 2020 (edited) My $0.05, note no check if when doing ssget that you pick original text as well. Used strcat rather than change better way to go (defun c:jtxt ( / ss obj toch tnew obj obj2) (command "style" "rs" "romans" "2.2" "0.8" "" "" "" "") (setq obj (vlax-ename->vla-object (car (entsel "\nPick text to change: ")))) (setq toch (vla-get-textstring obj)) (setq ss (ssget (list (cons 0 "text")))) (setq x -1) ; ss starts at 0 (repeat (sslength ss) (setq obj2 (vlax-ename->vla-object (ssname ss (setq x (+ x 1))))) (setq tnew (vla-get-textstring obj2)) (setq toch (strcat toch " " tnew)) (vla-delete obj2) ) (vla-put-textstring obj toch) (vla-put-stylename obj "rs") (princ) ) Edited January 4, 2020 by BIGAL 1 Quote
Speedster2 Posted January 4, 2020 Author Posted January 4, 2020 Thanks a lot Bigal for your time and for the lisp. Helps me a lot Quote
Speedster2 Posted January 4, 2020 Author Posted January 4, 2020 On 1/3/2020 at 1:33 PM, Roy_043 said: Marko has identified the piece of code that causes the problem. The (= count slen) condition is true only once. Yeah Roy. Thanks for identifying my mistake. Quote
