CAD Jockey Posted January 2, 2020 Posted January 2, 2020 Raster Position / Priority in Model I have created various drawing sheet models within a dgn file and have various 2D drawing files referenced into the models. I want to pull in raster images (jpg’s) via the raster manager. What I can’t do is get the raster images to sit over the reference files, (they always seem to sit behind). I have tried highlighting the rasters using the ‘bring to front’ command in raster manager but this won’t do it. I have also tried setting the ‘priority’ of the rasters to maximum (+500). Any suggestions appreceiated. Quote
BIGAL Posted January 3, 2020 Posted January 3, 2020 No idea in MicroStation normally draw order fixes, anyway another trick move the raster to z=1 if you have a 2d dwg, if it has 3dlines etc then try z=1000 Autocad will support at times the Z value of objects in a plan view. Move 0,0,0 0,0,1 Quote
