CivilPrice Posted December 30, 2019 Posted December 30, 2019 Is it possible to create a custom elevation label using the given properties? I want to take the insert elevation, and subtract 1/2 of the nominal pipe size to give me an exact top and bottom of pipe for a pressure pipe network. It seems simple, but nothing I try seems to work, it just shows up in the label as regular text...??? I get that this is a big ask, but I am sure someone has tried it in the past. thanks! Eric Quote
CyberAngel Posted December 30, 2019 Posted December 30, 2019 Check out this page at Autodesk's Knowledge Base. You can use an expression in a point label and reference it (I guess) in a profile text component. Quote
CivilPrice Posted December 31, 2019 Author Posted December 31, 2019 Most Excellent Sir CyberAngel... indeed. Quote
SLW210 Posted December 31, 2019 Posted December 31, 2019 This would seem to be a Civil 3D question. Quote
CivilPrice Posted December 31, 2019 Author Posted December 31, 2019 Sorry. I was just searching for an answer and posted in the same forum from my search. Still having a bit of trouble trying to use the Nominal Pipe size in the expression.... Quote
SLW210 Posted January 2, 2020 Posted January 2, 2020 I have moved your thread to the Civil 3D & LDD Forum. It would also help to correct your information or at least mention in your post what CAD/Software you are using. No telling how many may have been looking for a Label Style Composer in Vanilla AutoCAD. Quote
