I am trying to retrieve the current dimension style on an open cad file to execute some of my other lisps instead of (Alert blah...), but am not successful.
Could someone take a quick look at this and let me know where I am getting it wrong? i had a quick look at tblnext and tblsearch and I think it is right! but maybe VLA could do this more efficiently - I have not gotten too deep into LISP though.
I also have two standards ( "STANDARD" and "Standard") depending on which one is the current dim style my code changes. is there a way to make it Case sensitive?
; condition based on current dim stlye
; "Tx Arial 1.65" "Tx CityBlueprint 2.38" "Standard"
(defun c:test (/ D1)
  (setq D1 (tblnext "DIMSTYLE")) ; getting current dimstyle name
  (setq D1 (cdr (assoc 2 D1))) ; getting dimstyle name
(while  (/= D1 nil) ; if dimstyle is not nil then proceed
  (setq D1(tblsearch "DIMSTYLE" D1)) ;; searching for dimstyle
 (cond
   ( (= (cdr (assoc 2 D1)) "Standard")
    (alert "Standard is selected")
   ( (= (cdr (assoc 2 D1)) "Tx Arial 1.65")
    (alert "Tx Arial 1.65 is selected")
   ( (= (cdr (assoc 2 D1)) "Tx CityBlueprint 2.38")
    (alert "Tx CityBlueprint 2.38 is selected")
 ); end cond
); end while
Please help
SAMPLE DIMENSION.dwgUnavailable
Edited by Sambuddy
edit text
@devitg I am not sure it this helps but I just uploaded the dims.
my lisp is complete just imagine instead of Alert I have c:do-1
thanks
I think you overprogrammed...
Shouldn't this be also good ?
(defun c:test nil
  (cond
    ( (= (getvar 'dimstyle) "Standard")
    ( (= (getvar 'dimstyle) "Tx Arial 1.65")
    ( (= (getvar 'dimstyle) "Tx CityBlueprint 2.38")
    ( t
      (alert "Current DIMSTYLE not match any of hardcoded choices...")
Edited by marko_ribar
  Quote
I am ashamed of myself - thank you for the getvar 'dimstyle.
I knew there is a variable but I kept looking into -dimstyle and never thought about your approach.
Thank you very much marko_rebar
I guess I am not the one grinding on boxing day! hah!
Happy Holidays
now that I have you here, could you help me with another problem I have been facing:
(if (not c:BLAH)(load "BLAH"))
is there another way to test whether a lisp is or not?
  On 12/26/2019 at 7:47 PM, Sambuddy said:
..... is there a way to make it Case sensitive
assume you have list
(setq lst '( "STANDARD"  "standard" "Tx Arial 1.65" "Tx CityBlueprint 2.38" ) )
case sensitive use wcmatch
(alert
  (strcat (cond ( (car (vl-remove-if-not ''((x) (wcmatch x (getvar 'dimstyle))) lst) ) )
        	("oops! Nothing"))
      	" is selected"
FWIW another but not case sensitive
(alert
  (if (setq x (vl-position (getvar 'dimstyle) lst))
    (strcat (nth x lst) " is selected")
Edited by hanhphuc
syntax color
  • 2 weeks later...
@hanhphuc
Great! Thank you very much.
I can now arrange my lisp based on the dim style criteria much more easier that changing my text every time.
Thanks a lot!
