How to Trim Multiple Dimesnion
pmadhwal7
6 hours ago, pmadhwal7 said:
Please check my sample file
since your reference line is horizontal (start & end Y-coordinate identical) so No need LISP
Firstly, select crossing partially i.e: bottom part of all dimension
Command: STRETCH
Stretching selected objects by last window...395 found
Specify base point or [Displacement] <Displacement>:             <--- pointing tip of bottom arrow then move vertically using polar tracking
Specify second point or <use first point as displacement>:      <--- intersection point to reference line
Command: STRETCH
Hi Hanhphuc,   the best way is "make it simple " , like your answer. Simple and clear .
  • Thanks 1
Command: STRETCH
thanks sir i ama already following this method
  • Dislike 1
