How to trim multiple dimension at once in autocad 2020 trim command not working on dimension
What exactly do you want to "trim"?  Is it the extension lines?  You do know that the length of these lines is controlled by a system variable?
6 hours ago, pmadhwal7 said:
Please check my sample file
since your reference line is horizontal (start & end Y-coordinate identical) so No need LISP
Firstly, select crossing partially i.e: bottom part of all dimension
Command: STRETCH
Stretching selected objects by last window...395 found
Specify base point or [Displacement] <Displacement>:             <--- pointing tip of bottom arrow then move vertically using polar tracking
Specify second point or <use first point as displacement>:      <--- intersection point to reference line
Command: STRETCH
Hi Hanhphuc,   the best way is "make it simple " , like your answer. Simple and clear .
  • Thanks 1
Command: STRETCH
thanks sir i ama already following this method
  • Dislike 1
