Dayananda Posted December 24, 2019 Posted December 24, 2019 (setq ssblock1(ssadd ent1 ssblock1 )) I have a selection set of blocks. Next I need rearrange this selection set increasing X and Y direction of insertion point to insert the serial number. as shown in the image. Quote
hanhphuc Posted December 24, 2019 Posted December 24, 2019 (edited) 4 hours ago, Dayananda said: (setq ssblock1(ssadd ent1 ssblock1 )) I have a selection set of blocks. Next I need rearrange this selection set increasing X and Y direction of insertion point to insert the serial number. as shown in the image. 1.ssget 2.populate selection set as list 3.vl-sort function to sort increasing X-coordinates 4.loop using mapcar/ repeat / foreach / while to do it (serial number as TEXT) (defun c:test ( / i f s l a b ) (and (setq i -1 f '((x e)(assoc x (entget e))) s (ssget '((0 . "INSERT")))) (setq l (vl-sort (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) ''((a b)(< (cadr (f 10 a))(cadr (f 10 b) )))) a (cdr (f 10 (car l))) ) (foreach x l (grdraw a (setq b (cdr (f 10 x))) 1)(setq a b) ;;; Try put code your serial number here ;;; (princ (strcat "\nPut your Serial number : " (itoa (setq i (1+ i))))) ) ) (princ) ) To put serial number TEXT, try use entmake function, cons with dxf index 0, 1, 10, 40. strcat for prefix, example 'i' is incremental value, i.e: ( cons 1 (strcat "GF-S-" (itoa i)) ) Edited December 24, 2019 by hanhphuc 1 Quote
