pmadhwal7 Posted December 23, 2019 Posted December 23, 2019 how to place incremental value like 0,10,20,30 or 0,9,18,27 in autocad Quote
hanhphuc Posted December 23, 2019 Posted December 23, 2019 24 minutes ago, pmadhwal7 said: how to place incremental value like 0,10,20,30 or 0,9,18,27 in autocad basic of incremental , assume i= incremental value (setq x (+ x i)) while repeat mapcar foreach example: using repeat (defun c:tt ( / i x) (setq i 10 x 0) (repeat 10 (getstring "Press any key..") (princ (rtos (setq x (+ x i))2)) ) (princ) ) Quote
pmadhwal7 Posted December 23, 2019 Author Posted December 23, 2019 4 minutes ago, hanhphuc said: basic of incremental , assume i= incremental value (setq x (+ x i)) while repeat mapcar foreach example: using repeat (defun c:tt ( / i x) (setq i 10 x 0) (repeat 10 (getstring "Press any key..") (princ (rtos (setq x (+ x i))2)) ) (princ) ) how can place those as a text Quote
hanhphuc Posted December 23, 2019 Posted December 23, 2019 25 minutes ago, pmadhwal7 said: how can place those as a text entmake or entmakex (entmake (list '(0 . "TEXT") '(40 . 3) (cons 1 (rtos x 2) ) (list 10 0 x)) ) where should you put this line of code in previous code? try it & learn Quote
pmadhwal7 Posted December 24, 2019 Author Posted December 24, 2019 16 hours ago, hanhphuc said: Sir i have an lsp which place incremental number like 1,2,3.... like this lsp can i din't get any lsp which palce 0,9,18,27, or 10,20,30 entmake or entmakex (entmake (list '(0 . "TEXT") '(40 . 3) (cons 1 (rtos x 2) ) (list 10 0 x)) ) where should you put this line of code in previous code? try it & learn Quote
Lee Mac Posted December 24, 2019 Posted December 24, 2019 You can use my Incremental Numbering Suite, specifying an increment of 9 or 10. 1 Quote
