I am not even sure how to pose this question - so here she goes:
I am not quite sure if you can select content with different colours within a text (see attachment). The code below only finds text colour selected by the layer.
Is there a way?
My whole intention is to sort them so that say if I pick BELL (colour 150) or RORGERS (colour 22) then the white text strings and colour 150 remains and the rest be removed - sorting by colour and merging the text condition the selection and colour!!!
Possible?
(setq ss (ssget "X" '((0 . "*TEXT")(62 . 1))))
if yes...how???
text sample.dwgUnavailable
Is there a way?
Possible?
if yes...how???
Expand
Difficult to say as I cannot open the drawing as it is in a later version than the one I use.
MText formatting is embedded within the text content (here is a reference for the majority of available formatting codes); as such, you will need to test the text content of the presence of the colour formatting code "\C<colour>;" where <colour> is the ACI colour number.
  Quote
how do I implement that onto a code? a little more detail please
  • Obtain a selection set of all MTEXT entities within the target space.
  • Iterate over the set (using one of the methods described here).
  • Obtain the full text content held by each MTEXT entity (concatenate all DXF group 3 & 1 values).
  • Use wcmatch to test for the existence of \C<colour>; within the content, where <colour> is the ACI colour number you require.
Thank you Lee Mac,
I believe I can follow these guidelines for a hope of filtering colours within a text.
