Trying to use Annotate a Contour Line and having an Error
Thanks in advance!  By the way, It has worked and just stopped working for some reason.  Here is the error message I get
Command: LC
Error: no function definition: VLAX-GET-ACAD-OBJECTAutoCAD variable setting rejected: "osmode" nil
Command:
Here is the LISP I was trying to use
 ; Annotate a Contour Line
; BY: Tom Beauford - 7/11/2005 Modified By: Michael Hamann 7/13/2015
; (load "LabelContour.lsp") LabelContour With Decimal
(defun c:LC (/ *ERROR* Trl0s mspace om osz e ent pt tblname Rot str mtextobj ent el)
  (defun *ERROR* (s)                    ; If an error (such as CTRL-C) occurs
                                      ; while this command is active...
    (if (/= s "Function cancelled")
      (princ (strcat "\nError: " s))
    (grtext -1 "")                      ; Clear status line.
    (setvar "osmode" om)
    (setvar "osnapz" osz)
  (defun Trl0s (String); remove trailing zero(s) beyoud the decimal
      (if (= (rem (atof String) 10.0) 0); it's a whole multiple of 10 keep any zero(s) before the decimal
 (itoa (atoi String)); then
 (vl-string-right-trim ".0" String); else
      ); if
  (setq mspace (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
            om (getvar "osmode")
            osz (getvar "osnapz")
  (setvar "osnapz" 0)
  (setvar "osmode" 514)
  (setq pt (getpoint"\nSelect point on Contour Line: ")
            e (nentselp pt)
            ent (car e)
            pt (cadr e)
            tblname (car(ade_odgettables ent))
  (setq Rot (getangle pt "\nPick or Enter angle..." )
            str (Trl0s(rtos (caddr pt) 2 3)))
  (ade_errsetlevel 2)
  (if(ade_odgettables ent)
    (cond
      ((ade_odgetfield ent (car(ade_odgettables ent)) "ELEV" 0)
      (setq str (itoa(ade_odgetfield ent (car(ade_odgettables ent)) "ELEV" 0))))
      ((ade_odgetfield ent (ade_odgettables ent) "ELEVATION" 0)
      (setq str (Trl0s(rtos(ade_odgetfield ent (ade_odgettables ent) "ELEVATION" 0))2 3)))
  (ade_errsetlevel 0)
  (princ "\nElev = ")(princ str)
  (setq mtextobj (vla-addMText mspace (vlax-3d-point pt) 0.0 str))
  (vla-put-attachmentPoint mtextobj acAttachmentPointMiddleCenter)
  (vla-put-insertionPoint mtextobj (vlax-3d-point pt))
  (vla-put-Rotation mtextobj Rot)
  (vla-put-backgroundfill mtextobj :vlax-true); mask on with background color
  (setq el (entget (vlax-vla-object->ename mtextobj)))
  (setq el (subst (cons 45 1.13) (assoc 45 el) el)) ;Set MaskSize 1.13 × TextSize
  (entmod el)
Edited by mike3_21_21
It has worked and just stopped working for some reason.  I should have mentioned that.
So it turns out, this wasn't the LISP. Didn't think it was.  Another problem altogether.  Here was my search of fixes.  I basically got the Registry fix by exporting from a working computer.  In fact, I've attached here.  Hope it helps someone else.
error: no function definition: VLAX-ENAME->VLA-OBJECT; (vl-load-com)
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/error-no-function-definition-vlax-ename-gt-vla-object-vl-load/td-p/7920349
https://www.cadforum.cz/cadforum_en/error-no-function-definition-vlax-ename-vla-object-tip12131
https://www.landfx.com/kb/autocad-fxcad/errors/item/3433-no-function-definition.html
AutoCADreg.reg
Very unusual to screw the registery, should have worked out of the box. has some one been playing with the registery.
Something might have deleted some items I suspect.  It could have been virus protection or some registry cleaner.  I was having audio issues prior to this.
Yeah some registry cleaner really good at screwing stuff up rather than fixing.
