Hi all, I have lots of texts in autocad and I need to a lisp or function to extract numbers from text in a list in the following way:
"lili/=0.50@@0.573#0.53" >> (0.50 0.573 0.53)
"/= 0.00@ 20" >> (0.00 20)
" lili/= 23320: @" >> (23320)
":12" >> (12)
Can someone help me?
Edited by amir0914
":12" >> (12)
Does the (## ## ##) mean you want them as a list?
Yes, exactly
Something like this perhaps:
(defun ParseIt (str)
  (read
    (vl-list->string
      (append
        '(40) ; "(".
        (mapcar
          '(lambda (int) (if (or (= 46 int) (<= 48 int 57)) int 32))
          (vl-string->list str)
        '(41) ; ")".
Edited by Roy_043
  (read
    (vl-list->string
      (append
        '(40) ; "(".
        (mapcar
        '(41) ; ")".
Thanks a lot, but it has a minor problem :
lili/=0.50@@0.573#0.53" >> (0.5 0.573 0.53)
In this result 0.5 must be 0.50 , it means the program remove the last zero, while I need exact the same numbers in string.
This then means that you want to extract the numbers as strings, right?
You may want to consider the 'splitstring' function used by my Incremental Array program:
(defun incarray:splitstring ( str / lst )
    (setq lst (vl-string->list str))
    (read (vl-list->string (vl-list* 40 34 (incarray:split lst (< 47 (car lst) 58)))))
(defun incarray:split ( lst flg )
    (cond
        (   (null lst) '(34 41))
        (   (member (car lst) '(34 92))
            (if flg
                (vl-list* 34 32 34 92 (car lst) (incarray:split (cdr lst) nil))
                (vl-list* 92 (car lst) (incarray:split (cdr lst) flg))
        (   (or (< 47 (car lst) 58) (and (= 46 (car lst)) flg (< 47 (cadr lst) 58)))
            (if flg
                (vl-list* (car lst) (incarray:split (cdr lst) flg))
                (vl-list* 34 32 34 (car lst) (incarray:split (cdr lst) t))
        (   flg (vl-list* 34 32 34 (car lst) (incarray:split (cdr lst) nil)))
        (   (vl-list* (car lst) (incarray:split (cdr lst) nil)))
Example:
_$ (incarray:splitstring "lili/=0.50@@0.573#0.53")
("lili/=" "0.50" "@@" "0.573" "#" "0.53")
To parse numbers as strings:
; (KGA_String_TokenizeAlt "lili/=0.50@@0.573#0.53" "0123456789.")
(defun KGA_String_TokenizeAlt (str keepSet / ret sub)
  (setq keepSet (vl-string->list keepSet))
  (setq str (vl-string->list str))
  (repeat (1+ (length str))
    (cond
      ((vl-position (car str) keepSet)
        (setq sub (cons (car str) sub))
      (sub
        (setq ret (cons (vl-list->string (reverse sub)) ret))
        (setq sub nil)
    (setq str (cdr str))
  (reverse ret)
Edited by Roy_043
    (cond
      (sub
        (setq sub nil)
  (reverse ret)
Thank you Roy_043 , that's great.
I guess it depends on how much validation you require on whether or not a set of characters really represent a number.
agree!
1e2
1e-8
1.2e3
1.23e-4
1e+3
Hello again and thanks to Roy_043 and Lee Mac for replying.I have another question. How can I check a string that it is numeric?
("14")   >> T
("15.30") >> T
("GtH") >> F
("FG120") >> F
(")&L") >> F
(distof "14")
(distof "15.30")
(distof "GtH")
(distof "FG120")
(distof ")&L")
