Missing Properties Palette
I had to reinstall my AutoCAD 13 LT after my hard drive crashed at home.  After resetting a lot of variables I worked on a file and used the Properties command in the "Standard" toolbar. The palette appeared and I moved it off to the side then it disappeared. ( I may have clicked on something.)  I haven't been able to get it to reappear.  When I select PROPERTIES from the toolbar, nothing happens.  The command line shows either properties or properties close.  Hopefully some one knows how I can get it back.  I use it a lot.
I finally found the palette hiding along the very edge of the screen.  Thanks anyway.
  • Thanks 1
