I have this block of text as you can see in the image below, and in the window show me  this "VIGA V-SS01 (.25X .50)", BUT I DONT WANT THAT SHOW ME THIS.
I want to the program ask me a question first, for example: What is the name?
so I will set the answer of this question in the block I have.
SO, I want to have this in the window "VIGA V- (AND THE ANSWER OF THE QUESTION)"
EXAMPLE:
Computer: What is the name?
User write: L22
Then, that will show me:
"VIGA V- L22"
I will glad if you can help me, If you have already notice, I dont know to much about the topic.
Expand
(setq str (getstring t "\nWhat is the name? VIGA V- ") )
;change this
'(1 . "%%UVIGA V-SS01 (.25X .50)")
;to
(cons 1 (strcat "VIGA V- " str))
  • Thanks 1
add this line before this block of text
(setq str (getstring "\Type string"))
Then replace 7th line with
  Quote
'(1 . "%%Uviga v-ss01 (.25x.50)")
Expand
with
(cons 1 (strcat "VIGA V- " str ))
  • Thanks 1
