jw24 Posted December 10, 2019 Posted December 10, 2019 AutoCAD 2018, Windows 10 x64 Enterprise 1803 I have added a custom path in the Support File Search Path to include a specific dwg which contains some custom blocks of mine. When I add the path, everything works as I would expect. When I restart CAD, the path to my dwg automatically updates itself, appending 2 x back-slashes to the end of the path, which means the dwg doesn't get loaded and I can't insert my custom blocks. If I go in and edit the path, removing the two back-slashes, everything works again. This only happens to my custom path, no other support file paths. Anyone got any ideas? Quote
rkmcswain Posted December 10, 2019 Posted December 10, 2019 Expand "Working Support File Search Path". Is this path listed there? Quote
BIGAL Posted December 10, 2019 Posted December 10, 2019 You can use lisp to set support paths, temp directories, template name etc etc. So in relation to the directory not existing this is at top of code I use. ; make temp directory (if (vl-file-directory-p "C:\\Acadtemp\\") (Princ "Acadtemp exists") (vl-mkdir "C:\\AcadTEMP\\") ) Quote
rkmcswain Posted December 11, 2019 Posted December 11, 2019 12 hours ago, jw24 said: It isn't at the moment, no That makes sense, because if a path isn't resolved, it can't become a "Working" path. There is no chance a startup routine is running to make this change? Quote
