Is there a way to add Text before or after a dimension. Such as adding "NOM." after dimension "100" ... end result "100 NOM.".
Using the Text override is not an option because if I change scale, I may forget to update.
There are a couple of different ways to add text to a dimension.  A simple Internet search on "add text to AutoCAD dimensions" will bring up plenty of links to click on.  Is the text going to be above or below the dimension?
  • Thanks 1
OK thanks, I didn't know it would be this easy.
When you add a pair of angle brackets <> in your text property, that inserts the measurement and allows you to use any other text around it. Your example would appear as "<> NOM" in the text field but show up as "100 NOM" in the dimension (assuming the measurement is 100).
Edited by CyberAngel
  • Thanks 1
OK thanks for that advice. It works well.
