sketch11 Posted December 7, 2019 Share Posted December 7, 2019 Is there a way to add Text before or after a dimension. Such as adding "NOM." after dimension "100" ... end result "100 NOM.". Using the Text override is not an option because if I change scale, I may forget to update. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 8, 2019 Share Posted December 8, 2019 There are a couple of different ways to add text to a dimension. A simple Internet search on "add text to AutoCAD dimensions" will bring up plenty of links to click on. Is the text going to be above or below the dimension? 1 Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 9, 2019 Author Share Posted December 9, 2019 OK thanks, I didn't know it would be this easy. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted December 9, 2019 Share Posted December 9, 2019 (edited) When you add a pair of angle brackets <> in your text property, that inserts the measurement and allows you to use any other text around it. Your example would appear as "<> NOM" in the text field but show up as "100 NOM" in the dimension (assuming the measurement is 100). Edited December 9, 2019 by CyberAngel 1 Quote Link to comment Share on other sites More sharing options...
sketch11 Posted December 10, 2019 Author Share Posted December 10, 2019 OK thanks for that advice. It works well. Quote Link to comment Share on other sites More sharing options...
