Is there a way to insert a block at the same rotation as another block closer to the center of my screen?
-> I zoomed, I called the command, and the new block will be inserted in the block closest to my zoom.
I got a .dwg with the example.
Drawing1.dwg
You can obtain the coordinates of the center of the drawing window using the VIEWCTR system variable; using these coordinates, you can then obtain the block reference with insertion point coordinates such that (distance <insertion-point> <viewctr>) is minimised.
