ramon Posted December 4, 2019 Posted December 4, 2019 I need to Write a lisp routine that has the user pick 2 points (opposite corners) then draws a polyline through 4 points using the two points specified by the user and the two other corners I Do not want to use the Rectangle command. After the polyline has been drawn, change the polyline width to .125 (for all segments). The lisp file will then create a layer, called `Object' that is green and place the polyline on that layer. Quote
ronjonp Posted December 4, 2019 Posted December 4, 2019 What have you written so far? Post your effort and perhaps we can assist. Quote
ramon Posted December 4, 2019 Author Posted December 4, 2019 (defun C:Testing () (setq P1 (getpoint "\nLower-left corner: ") P3 (getcorner P1 "\nUpper-right corner") P2 (list (car P3) (cadr P1)) P4 (list (car P1) (cadr P3)) P1A (list (+ (car P1) 0.1) (+ (cadr P1) 0.1)) P2A (list (- (car P2) 0.1) (+ (cadr P2) 0.1)) P3A (list (- (car P3) 0.1) (- (cadr P3) 0.1)) P4A (list (+ (car P4) 0.1) (- (cadr P4) 0.1)) ) (command "-osnap" "none") (command "LINE" P1 P2 P3 P4 "C") (command "LINE" P1A P2A P3A P4A "C") ) Quote
ronjonp Posted December 4, 2019 Posted December 4, 2019 Is this a homework assignment ? Using the rectang command would be the most direct route. Quote
ronjonp Posted December 4, 2019 Posted December 4, 2019 (edited) 30 minutes ago, ramon said: It is. Hahaha .. I admire your honesty. Well hope you can learn from this ( you still have to do the layer part ) (defun c:testing (/ p1 plw p2 p3 p4) ; < - Localize variables!! (setq p1 (getpoint "\nLower-left corner: ") p3 (getcorner p1 "\nUpper-right corner") p2 (list (car p3) (cadr p1)) p4 (list (car p1) (cadr p3)) ;;; p1a (list (+ (car p1) 0.1) (+ (cadr p1) 0.1)) ;;; p2a (list (- (car p2) 0.1) (+ (cadr p2) 0.1)) ;;; p3a (list (- (car p3) 0.1) (- (cadr p3) 0.1)) ;;; p4a (list (+ (car p4) 0.1) (- (cadr p4) 0.1)) ) (command "-osnap" "none") (setq plw (setvar 'plinewid 0.125)) (setvar 'plinewid 0.125) (command ".pline" p1 p2 p3 p4 "c") ;;; (command "LINE" p1 p2 p3 p4 "C") ;;; (command "LINE" p1a p2a p3a p4a "C") (setvar 'plinewid plw) ) Edited December 4, 2019 by ronjonp Quote
ramon Posted December 4, 2019 Author Posted December 4, 2019 thank you for the the knowledge you have bestowed upon me. Quote
