How can I make the autolisp place a text on a line that is already made by the autolisp?
Im beginner, I have this:
(setq p1 (getpoint "\nPunto Inicial:"))
      (setq p2 (polar p1 (* 1.5 pi) 0.5))
       (entmakex (list '(0 . "line") (cons 10 p1) (cons 11 p2) '(62 . 2)))
So, the line I drawn is the yellow one below in the image. And, the text I want put is the magenta one.
how can I do this?
Thanks for your help
10 minutes ago, ronjonp said:
Why don't you use an attributed block?
how i can do this? sorry as I said Im a beginner
I will glad for your help
Like attached:
example.dwg
Here is code to place that text although it's not how I'd approach it.
(entmakex (list	'(0 . "TEXT")
		'(100 . "AcDbEntity")
		'(8 . "YourTextLayer")
		'(100 . "AcDbText")
		(cons 10 (mapcar '+ p1 '(0.17 0.29 0.)))
		'(40 . 0.1)
		'(1 . "%%UVIGA V-SS01 (.25X.50)")
		'(50 . 0.)
		'(41 . 1.)
		'(51 . 0.)
		'(11 0. 0. 0.)
Edited by ronjonp
  • Thanks 1
On 12/3/2019 at 2:13 PM, ronjonp said:
(entmakex (list '(0 . "TEXT") '(100 . "AcDbEntity") '(8 . "YourTextLayer") '(100 . "AcDbText") (cons 10 (mapcar '+ p1 '(0.17 0.29 0.))) '(40 . 0.1) '(1 . "%%UVIGA V-SS01 (.25X.50)") '(50 . 0.) '(41 . 1.) '(51 . 0.) '(11 0. 0. 0.) ) )
thanks you for your help,  its works.  :)
