autocad 2013 - blank drawing on startup not close
Blank drawing created on startup is not replaced by 1st drawing opened why?
Why do you think it should? Maybe take a look at the 'startup' variable so you don't get a blank drawing when Autocad starts, but once a drawing is open it is the user who has to close it
i resolve issue just copy original acadiso.dwt in the folder. now the drawing1.dwg close after open a new drawing
Under Config, File, Template you can set which dwt is to be used on start up and New command, mine is configured to a custom one on my D drive.
