sketch11 Posted November 30, 2019 Posted November 30, 2019 With the respect to the scrollbar width on the newer versions of AutoCAD, many complain that it's far too thin. I agree. Is there a plugin that can change this width? Other than QuickPik. Quote
Cad64 Posted November 30, 2019 Posted November 30, 2019 I guess you're referring to the Properties palette scroll bar? Yes, it is thin but there is no way to adjust that within Autocad. If it bothers you, I think QuickPik is probably your only option. Have you tried it? I stopped using the Properties palette a few years ago. I use Quick Properties and customize it so I only see the properties that I need instead a big palette full of stuff I have to scroll through. 1 Quote
sketch11 Posted December 1, 2019 Author Posted December 1, 2019 OK thanks I'll give this a try. Quote
