brandalf_the_semiGray Posted November 26, 2019 Share Posted November 26, 2019 (edited) I have been just starting to delve into the world of autoLISP, and have seen snippets of code that have, for example defun c: I was able to find out that this makes it so that the user is able to run the function from the command line. Now, the part where I get confused is when I see things like defun rh: What does this line do? I've seen variants in Lee Mac's code that have LM: Is the ':' some sort of a namespace, or scope resolution operator? Can someone point me in the direction of where I can learn more about its use? Thanks in advance! Edited November 26, 2019 by brandalf_the_semiGray Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 26, 2019 Share Posted November 26, 2019 [SEE COLON] simply means that the function name following can be used at the command line, like a core function (i.e.: Line, Circle, Pline). If you omit the prefix, or use your own like KW:Fun, then you have to include that part when you call the function name, along with enclosing it in parenthesis (KW:Fun) Some authors do this to their functions for identification purposes. 1 Quote Link to comment Share on other sites More sharing options...
dlanorh Posted November 26, 2019 Share Posted November 26, 2019 In addition to @rkmcswain excellent answer above, look at these two functions, and spot the differences (defun function_name (passed vars / local_vars) expressions ) (defun C:function_name ( / local_vars) expressions ) 2 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 26, 2019 Share Posted November 26, 2019 You may wish to refer to my explanation here. 1 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 26, 2019 Share Posted November 26, 2019 3 hours ago, dlanorh said: In addition to @rkmcswain excellent answer above, look at these two functions, and spot the differences (defun function_name (passed vars / local_vars) expressions ) (defun C:function_name ( / local_vars) expressions ) Note that the "c:" prefix has no bearing on whether or not the function may accept arguments - _$ (defun c:foo ( x ) (+ x 2)) C:FOO _$ (c:foo 2) 4 The "c:" prefix is solely use to make a function available as a command which may be executed directly at the AutoCAD command line. Of course, evaluating a function which requires arguments as a command directly at the command line will result in a "too few arguments" error, but these two properties of a function are not related. 1 Quote Link to comment Share on other sites More sharing options...
brandalf_the_semiGray Posted November 26, 2019 Author Share Posted November 26, 2019 (edited) 3 hours ago, dlanorh said: In addition to @rkmcswain excellent answer above, look at these two functions, and spot the differences (defun function_name (passed vars / local_vars) expressions ) (defun C:function_name ( / local_vars) expressions ) The differences that catch my eye are the c : prefix to allow command line invocation, as well as one of the functions having passed variables. 25 minutes ago, Lee Mac said: You may wish to refer to my explanation here. This was precisely what I was looking for. Thank you very much to all three of you. Edited November 26, 2019 by brandalf_the_semiGray 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 27, 2019 Share Posted November 27, 2019 (edited) You can call c : defuns or plain defuns in code I often add run code on a (load "mylisp") to run straight away 1st time. (c:function_name) put this as last line of code also (moblk) as last runs my move block code which is wrapped in a defun called moblk but no need for keyboard input use when really only want to run once. (function_name 12 22) normal function call check to see if lisp is loaded looks for the defun (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq ans (AH:getvalsm (list "This is heading" "Line 1" 5 4 "11" "Line2" 8 7 "22" "Line3" 8 7 "33" "Line4" 8 7 "4"))) in a menu these are the same ^c^c(load "mover") mover ^c^c(load "mover")(c:mover) Edited November 27, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
