Hi,
I would like to add to this lisp a "variable" scale value.
Now is 1.00 but sometime I need to scale it down.
It could work like this:
  1. 1.00 by default
  2. Ask me if I want to change the scale value
  3. Keep the new value until I close the DWG.
Can someone help me on this?
Thanks,
Santo
(defun c:CRD (/ sp p)
(command "UCS" "world")
  (setq sp
         (vlax-get (vla-get-activelayout
                     (vla-get-ActiveDocument (vlax-get-acad-object)))
                   'Block)
  (if (tblsearch "BLOCK" "STREET2" )
    (while (setq p (getpoint "\nSpecify point :"))
      (vla-put-textstring
        (car (vlax-invoke
               (vla-insertblock
                 sp
                 (vlax-3d-point p)
                 "STREET2"
                 1.0
                 1.0
                 1.0
                 0.0)
               'getattributes))
	(rtos (/ (caddr p) 1000.) 2 2)
(command "UCS" "_p")
  )(vl-load-com)
Edited by whosa
You could try something like this -
(defun c:crd ( / ang att blk ins obj scl spc )
    (setq blk "street2")
    (if (tblsearch "block" blk)
            (if (null crd:scl)
                (setq crd:scl 1.0)
            (initget 6)
            (if (setq scl (getreal (strcat "\nSpecify scale <" (rtos crd:scl 2) ">: ")))
                (setq crd:scl scl)
                (setq scl crd:scl)
            (setq ang (angle '(0 0) (trans (getvar 'ucsxdir) 0 (trans '(0 0 1) 1 0 t) t))
                  spc (vlax-get-property (vla-get-activedocument (vlax-get-acad-object))
                          (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)
            (while (setq ins (getpoint "\nSpecify insertion point <exit>: "))
                (if (setq obj (vla-insertblock spc (vlax-3D-point (trans ins 1 0)) blk scl scl scl ang)
                          att (car (vlax-invoke obj 'getattributes))
                    (vla-put-textstring att (rtos (/ (caddr (trans ins 1 0)) 1000.0) 2 2))
        (princ (strcat "\nBlock " blk " is not defined in the active drawing."))
(vl-load-com) (princ)
Edited by Lee Mac
(if (and (or (tblsearch "BLOCK" "STREET2")
             (alert "Block < STREET2 > was not found <!>")
         (or *sclval* (setq *sclval* 1.0))
         (setq
           *sclval* (cond ((getdist (strcat "\nSpecify the scale value < "
                                            (vl-princ-to-string *sclval*)
                          (*sclval*)
    (vla-put-textstring
      (car (vlax-invoke
             (vla-insertblock
               sp
               (vlax-3d-point p)
               "STREET2"
               *sclval*
               *sclval*
               *sclval*
               0.0
             'getattributes
A couple of choices rather than initget
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (atof (nth 0 (ah:butts but "v"  '("Choose 1:  " "1" "0.75" "0.5" "0.25" "0.1" )))))
remembers last picked.
Another by lee-mac
(if (not LM:LISTBOX)(LOAD "ListBoxV1-2.lsp")
(setq lst (list "1" "0.75" "0.5" "0.25" "0.1" ))
(LM:LISTBOX "choose" lst 2)
