whosa Posted November 25, 2019 Posted November 25, 2019 (edited) Hi, I would like to add to this lisp a "variable" scale value. Now is 1.00 but sometime I need to scale it down. It could work like this: 1.00 by default Ask me if I want to change the scale value Keep the new value until I close the DWG. Can someone help me on this? Thanks, Santo (defun c:CRD (/ sp p) (command "UCS" "world") (setq sp (vlax-get (vla-get-activelayout (vla-get-ActiveDocument (vlax-get-acad-object))) 'Block) ) (if (tblsearch "BLOCK" "STREET2" ) (while (setq p (getpoint "\nSpecify point :")) (vla-put-textstring (car (vlax-invoke (vla-insertblock sp (vlax-3d-point p) "STREET2" 1.0 1.0 1.0 0.0) 'getattributes)) (rtos (/ (caddr p) 1000.) 2 2) ) ) ) (princ) (command "UCS" "_p") )(vl-load-com) Edited November 25, 2019 by whosa Quote
Lee Mac Posted November 25, 2019 Posted November 25, 2019 (edited) You could try something like this - (defun c:crd ( / ang att blk ins obj scl spc ) (setq blk "street2") (if (tblsearch "block" blk) (progn (if (null crd:scl) (setq crd:scl 1.0) ) (initget 6) (if (setq scl (getreal (strcat "\nSpecify scale <" (rtos crd:scl 2) ">: "))) (setq crd:scl scl) (setq scl crd:scl) ) (setq ang (angle '(0 0) (trans (getvar 'ucsxdir) 0 (trans '(0 0 1) 1 0 t) t)) spc (vlax-get-property (vla-get-activedocument (vlax-get-acad-object)) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace) ) ) (while (setq ins (getpoint "\nSpecify insertion point <exit>: ")) (if (setq obj (vla-insertblock spc (vlax-3D-point (trans ins 1 0)) blk scl scl scl ang) att (car (vlax-invoke obj 'getattributes)) ) (vla-put-textstring att (rtos (/ (caddr (trans ins 1 0)) 1000.0) 2 2)) ) ) ) (princ (strcat "\nBlock " blk " is not defined in the active drawing.")) ) (princ) ) (vl-load-com) (princ) Edited November 25, 2019 by Lee Mac 1 Quote
Tharwat Posted November 25, 2019 Posted November 25, 2019 (if (and (or (tblsearch "BLOCK" "STREET2") (alert "Block < STREET2 > was not found <!>") ) (or *sclval* (setq *sclval* 1.0)) (setq *sclval* (cond ((getdist (strcat "\nSpecify the scale value < " (vl-princ-to-string *sclval*) " > : " ) ) ) (*sclval*) ) ) ) (while (setq p (getpoint "\nSpecify point :")) (vla-put-textstring (car (vlax-invoke (vla-insertblock sp (vlax-3d-point p) "STREET2" *sclval* *sclval* *sclval* 0.0 ) 'getattributes ) ) (rtos (/ (caddr p) 1000.) 2 2) ) ) ) 1 Quote
whosa Posted November 25, 2019 Author Posted November 25, 2019 Many thanks @Lee Mac and @Tharwat Quote
BIGAL Posted November 27, 2019 Posted November 27, 2019 A couple of choices rather than initget (if (not AH:Butts)(load "Multi Radio buttons.lsp")) (if (= but nil)(setq but 1)) (setq ans (atof (nth 0 (ah:butts but "v" '("Choose 1: " "1" "0.75" "0.5" "0.25" "0.1" ))))) remembers last picked. Another by lee-mac (if (not LM:LISTBOX)(LOAD "ListBoxV1-2.lsp") (setq lst (list "1" "0.75" "0.5" "0.25" "0.1" )) (LM:LISTBOX "choose" lst 2) 1 Quote
