visitor Posted November 23, 2019 Posted November 23, 2019 I need to convert a xml file into a .ply format. I started with a catproduct and I want to project that catproduct using a Virtek laser. In order to do so, I need a .ply and .cal files. How can I do that? Quote
Cad64 Posted November 24, 2019 Posted November 24, 2019 On 11/23/2019 at 8:49 PM, visitor said: I need to convert a xml file into a .ply format. I started with a catproduct and I want to project that catproduct using a Virtek laser. In order to do so, I need a .ply and .cal files. I'm not sure you can go from .xml to .ply, but if you have Catia, you could save your catproduct as a catpart and then save to .stl format. See here: https://www.divbyz.com/convert-3d-models-to-stl-files-catia Then you can use Meshlab to convert the .stl file to .ply format. Quote
