Dayananda Posted November 23, 2019 Posted November 23, 2019 ((-1 . <Entity name: 7ff4dca064a0>) (0 . "XRECORD") (330 . <Entity name: 0>) (5 . "2D2") (100 . "AcDbXrecord") (280 . 1) (7 . "Arial") (8 . "A09--T-") (40 . 20.0) (3 . "A1") (300 . "61") (3 . "A2") (300 . "69") (3 . "A3") (300 . "72")) In this list there are association code 3 several times. How can I get absorb the values relevant all values. and next how can I feed back new values to that code using (entmod(subst ( cons 3 ......? Quote
hanhphuc Posted November 23, 2019 Posted November 23, 2019 check this old thread --> massoc i'd suggest finding nth position (defun foo (i l / c x ls) (setq c 0) (repeat (length l) (setq x (nth (setq c (1+ c)) l)) (if (= (car x) i) (setq ls (cons c ls)) ) ) (reverse ls) ) assum l1 is your list (setq nl (foo 3 l1)) ; nl = nth / position list ;;;(9 11 13) ;; retrieve nth position in l1 (mapcar ''((x)(nth x l1)) nl) ;;;((3 . "A1") (3 . "A2") (3 . "A3")) to replace new item , assume your wanna replace same index 3 with new item '("B1" "B2" "B3") (defun bar (i new x l) (mapcar ''((a b) (setq l (subst (cons i a) (nth b l) l))) new x ) l ) (bar 3 '("B1" "B2" "B3") nl l1) ;((-1 . <Entity name: 7ff4dca064a0>) (0 . "XRECORD") (330 . <Entity name: 0>) (5 . "2D2") (100 . "AcDbXrecord") (280 . 1) (7 . "Arial") (8 . "A09--T-") (40 . 20.0) ;(3 . "B1") (300 . "61") (3 . "B2") (300 . "69") (3 . "B3") (300 . "72")) 1 Quote
Grrr Posted November 23, 2019 Posted November 23, 2019 Here are some quickly written functions that may be of help - ; (GetInstancesOf (lambda (x)(= 10 (car x))) (entget (car (entsel "\nPick polyline")))) ; >> ((10 1288.07 1710.1) (10 2258.12 2318.01) (10 2529.53 2318.01) (10 3871.5 1865.85) (10 4595.26 2368.25) (10 5032.54 2212.5)) ; tf - test function ; L - list (defun GetInstancesOf ( tf L ) ( (lambda (f tf L) (f tf L)) (lambda (tf L) (if (setq L (vl-member-if 'tf L)) (cons (car L) (f tf (cdr L))) ) ) tf L ) ); defun ; (SubstInstances '((x)(= 10 (car x))) '(0 2) '("Donald" "Trump") (entget (car (entsel "\nPick polyline")))) ; >> ; ((-1 . <Entity name: 76940ffd10>) (0 . "LWPOLYLINE") (330 . <Entity name: 76b2f399f0>) (5 . "269") (100 . "AcDbEntity") ; (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbPolyline") (90 . 6) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) ; "Donald" (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) ; (10 2258.12 2318.01) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) ; "Trump" (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) ; (10 3871.5 1865.85) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) ; (10 4595.26 2368.25) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) ; (10 5032.54 2212.5) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (210 0.0 0.0 1.0) ; ) ; sL - source list ; tf - test function ; nL - positions to subst ; aL - list of new items (defun SubstInstances ( tf nL aL sL / i ) (setq i -1) (mapcar (function (lambda (x / itm) (cond ( (not (tf x)) x) ( (not aL) x) ( (member (setq i (1+ i)) nL) (setq itm (car aL)) (setq aL (cdr aL)) itm) (x) ); cond ); lambda ); function sL ); mapcar ); defun And heres some test function (tested on a LWPOLYLINE, since it has multiple dxf 10 values in its elist and its a graphical entity which is suitable for a preview during testing) - (defun C:test ( / enx vL nL p p2 ) (and (setq enx (car (entsel "\nPick a polyline: "))) (setq enx (entget enx)) (member '(0 . "LWPOLYLINE") enx) (setq vL (GetInstancesOf '((x)(= 10 (car x))) enx)) (setq nL ('((f n) (reverse (f (1- n)))) '((n) (if (> n -1) (cons n (f (1- n))))) (length vL))) (progn (foreach n nL ; use 'nL' or a custom list like: '(0 2 5 12) (and (setq p2 (nth n vL)) (setq p (getpoint (cdr p2) (strcat "\nSpecify new " (itoa (1+ n)) (cond ( (nth n '("st" "nd" "rd" "th")) ) ("th") ) " vertex of the polyline: " ) ) ) (setq enx (SubstInstances '((x)(= 10 (car x))) (list n) (list (cons 10 p)) enx)) ; update within the iteration for a real-time preview (entmod enx) ); and ); foreach (princ "\nPress anything to restore the shape") (grread) (entmod (SubstInstances '((x)(= 10 (car x))) nL vL enx)) ); progn ) (princ) ); defun 1 Quote
