Autocad VBA, select from on the screen mtext object
select from on the screen mtext1 object  and send  textbox1 on userform
select from on the screen mtext2 object  and send textbox2 on userform
select from on the screen mtext3 object  and send textbox3 on userform
Please.
In  a lisp dcl you can not pick mtext while its open but can close and update same as a VBA form. Just search vba select Mtext it will use a Textstring method.
  • 1 month later...
I prepared a simple procedure that could help you more, please note it's preliminary so could have some issue, but the main scope has been reached.
TextDrToTextForm.rar
Edited by PeterPan9720
