 (setq
    adoc (vla-get-activedocument (vlax-get-acad-object))
    blocks (vla-get-blocks adoc)
    lays (vla-get-layers adoc)
    color (acad_colordlg 256)
Can someone to convert above code to AutoLisp.
Explain more what it is your trying to do. You can tblsearch for blocks and layers.
Edited by BIGAL
Visual lisp doesn't work with Autocad MAC.
It works only with Autolisp. So I am trying to convert to some codes to work with MAC.
Here is a way to make a list of layers and blocks.
You probably don't need adoc (not sure, if you need it, show us in what context)
And I don't know why you need (acad_colordlg ).  Can you do without?  Or any suggestion how else to get this (example pick an object, return the color of its layer... )
(defun layers_table ( / res)
  (setq res (list))
  (while (setq lay (tblnext "LAYER" (not lay)))
    (setq res (append res (list (cdr (assoc 2 lay)))))
  res
(defun blocks_table ( / res)
  (setq res (list))
  (while (setq blk (tblnext "BLOCK" (not blk)))
    (setq res (append res (list (cdr (assoc 2 blk)))))
  res
(defun c:test ( / blocks lays)
  (setq
    ;; you probably don't need adoc
    blocks (blocks_table)
    lays (layers_table)
    ;; color (acad_colordlg 256)
  (princ "\n -- BLOCKS -- \n")
  (princ blocks)
  (princ "\n -- LAYERS -- \n")
  (princ lays)
  • Thanks 1
Thanks . Your codes are good enough to start .
