;;; as function with path hard coded
(defun C:AddToolPalettePath ( / _pimp pFiles CurToolPath NetToolPath)
  (vl-load-com) (defun _pimp (s) (strcase (vl-string-trim " ;\\" (vl-string-translate "/" "\\" s))))
  (setq pFiles (vla-get-files (vla-get-preferences (vlax-get-acad-object))))
  (setq CurToolPath (_pimp (vla-get-ToolPalettePath pFiles)))
  (setq NetToolPath (_pimp "I:\\_CAD STANDARDS\\100 - CAD SUPPORT FILES\\200 - SUPPLEMENTARY FILES\\TOOL PALETTES"))
  (if (not (vl-string-search NetToolPath CurToolPath))
    (vla-put-toolPalettePath pFiles (strcat CurToolPath ";" NetToolPath)))
;;; or as subfunction with argument :
;;; (_AddToolPalettePath "I:\\_CAD STANDARDS\\100 - CAD SUPPORT FILES\\200 - SUPPLEMENTARY FILES\\TOOL PALETTES")
(defun _AddToolPalettePath ( $tp / _pimp pFiles CurToolPath NetToolPath)
  (setq NetToolPath (_pimp $tp))
You guys are awesome - thank you for explaining.  I spoke to another coder who refreshed my memory on how crappily Autodesk manages toolpalettes (i.e. the groups are stored in the registry via the profile and that a restart is required for changes to take effect).  I'd like to find the guys who programmed it this way and backhand them a few times.
Anyway, the suggestion I heard from him and have seen floating around online is it to have buttons in toolbar/ribbon to toggle the ToolPalette Path between the User's default and the network Palettes so then this group crap is irrelevant.  That's something to tackle for another day though.
P.S. 😆 the pimp function...
  • 4 years later...
Is there a way to to do the same thing to the Authoring Tool Palettes Location?
Haven't been able to find where it is located in the vla object acad/preferences/files or as a system variable like the tool palettes location can be updated/changed.
