is possible to have a lisp that put all entities that are on layer 0 lineweight to byblock?
i have this code but put even other layers on setbyblock lineweight
(vl-load-com)
(defun c:bf  (/ col cnt lop sel)
; Dynamic blocks don't update and I dont know why. Vla-update doesnt work. Vla-resetBlock works but all dynamic parametres are lost.
;;; subroutines
  ;; remove duplicated items in list
  (defun LM:unique  (l) ; by Lee Mac
    (if l
      (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))))
  ;; set "by block" to all entities in block definition
  (defun BB:setByBlock  (nam / blc blk)
    (setq blc (vla-get-blocks (vla-get-activedocument
(vlax-get-acad-object))))
    (setq blk (vla-item blc nam))
    (vlax-for x  blk
;;;     (vla-put-layer x "0")
;;;     (vla-put-color x acByBlock)
;;;     (vla-put-linetype x "ByLayer")
;;;    (vla-put-linetypescale x 1.0)
      (vla-put-lineweight x acLnWtByBlock)
;;;      (vla-put-entityTransparency x "ByBlock:")
;;;      (vla-put-material x "ByBlock")
      (if (eq (vla-get-objectName x) "AcDbBlockReference")
        (BB:setByBlock (vla-get-effectiveName x))))
;;; main
  (setq lop t)
  (while lop
    (princ "\nSelect blocks: ")
    (if (setq sel (ssget '((0 . "INSERT"))))
      (progn (setq cnt 0)
             (setq col nil)
             (repeat (sslength sel)
               (setq obx (vlax-ename->vla-object (ssname sel
cnt)))
               (setq col (cons (vla-get-effectiveName obx) col))
             (setq cnt (1+ cnt)))
      (setq col (LM:unique col))
      (foreach x col (BB:setByBlock x))
      (setq lop nil))
    (princ "\nNo selection")))
(vla-regen (vla-get-ActiveDocument (vlax-get-acad-object))
acActiveViewport)
(princ))
(vl-load-com)
;;; subroutines
    (if l
    (vlax-for x  blk
;;; main
  (setq lop t)
  (while lop
      (progn (setq cnt 0)
             (setq col nil)
cnt)))
      (setq lop nil))
acActiveViewport)
(princ))
Are you trying to set all entities in all blocks to layer 0, color byblock,  linetype bylayer and lineweight byblock?
It will not work with dynamic blocks because you are finding the effective name of the block, not the name of the block.
If the answer to the first question is yes then you need to iterate all the blocks in the block table (omitting layouts and xrefs). This should take care of the dynamic blocks.
yes but if i set linetype by layer i have a layer for axis but the lisp put all to layer 0 and linetype of all lines will be as layer 0.
OK try one of these.
The first is your original code corrected to to only set the lineweight of block entities that are on layer "0". I have moved the two sub functions outside the main function. This should also now do dynamic blocks and alters both the effectivename definition and the anonymous definition. This will only process the blocks in the selection set.
The second (c:lwbb) iterates the block definition table and requires no selection set. Again it will set the lineweight of block entities on layer "0", but it will process ALL block definitions except XREFS, LAYOUTS and DIMS (as far as possible). The DIMS part needs a bit of explaining as this assumes that your drawing units are not set to "Unitless" and the block defnitions  are not unitless. If this is the case any unitless blocks will not be processed.
Any problems let me know.
(defun LM:unique  (l) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))))
  (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  (vlax-for x  blk (if (= "0" (vlax-get-property x 'layer)) (vlax-put-property x 'lineweight acLnWtByBlock)))
(vl-load-com)
(defun c:bf ( / c_doc sel cnt obj col)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object)))
  (princ "\nSelect blocks : ")
  (cond (sel
          (repeat (setq cnt (sslength sel))
            (setq obj (vlax-ename->vla-object (ssname sel (setq cnt (1- cnt)))))
            (cond ( (= :vlax-true (vlax-get-property obj 'isdynamicblock))
                    (setq col (cons (vla-get-effectivename obj) col)
                          col (cons (vla-get-name obj) col)
                  (t  (setq col (cons (vla-get-effectiveName obx) col)))
            );end_cond
          );end_repeat
        ( (princ "\nNothing Selected"))
  );end_cond
  (vla-regen c_doc acActiveViewport)
(defun c:lwbb ( / c_doc c_blks)
        c_blks (vla-get-blocks c_doc)
  );end_setq
  (vlax-for blk c_blks
    (cond ( (and  (= :vlax-false (vlax-get-property blk 'isxref))   ;NOT an XREF
                  (= :vlax-false (vlax-get-property blk 'islayout)) ;NOT A LAYOUT
                  (/= 0 (vlax-get-property blk 'units))             ;NOT A DIMENSION
            );end_and
            (vlax-for itm blk
              (if (= "0" (vlax-get-property itm 'layer)) (vlax-put-property itm 'lineweight acLnWtByBlock))
            );end_for
    );end_cond
  );end_for
  (vla-regen c_doc acAllViewports)
);end_defun
Edited by dlanorh
code update
what must i use lm or bf? between codes give me bad argument type
type bf for your corrected original code
type lwbb for the second code. This has been updated above as there was a hyphen missing which caused the error.
I NEED THE SELECTION SET BUT GIVE ME ERROR WHY?
I only copy BF but don't do anything sorry
Edited by jim78b
For bf you need to copy bf lm:unique and bb:setbyblock then type bf to run it. Copy all of the below or download the attached.
(vl-load-com)
  (cond (sel
            );end_cond
          );end_repeat
  );end_cond
bf.lsp
28 minutes ago, jim78b said:
thanks a lot now work!
No problem. Sorry for the confusion.:thumbsup:
Sorry me for a lot of requests. Have a nice day
sorry in the lisp i need also that the color on layer 0 is set to byblock is possible to edit ? thanks
sorry don't work
; error: bad argument type: VLA-OBJECT nil
layer 0 color is not set to byblock
is there a come like setbylayer with a window to choose every time the options?
Missed that it was in an if statement. Attached amended, minimally tested and working on my system.
bf.lsp
Thank you so much i test it later .have a nice day
don' t work sorry gain i tried to create a block with 2 lines on layer 0 color bylayer and then a center line on layer ex:axis...
Edited by jim78b
