I can get the TAN value of the angle 300/1125 = 0.266666667  Now how can I get the  Angle  in digress or in radians by LISP.
  • To convert from degrees to radians, you would divide by 180 and multiply by pi.
  • To convert from radians to degrees, you would divide by pi and multiply by 180.
Such functions may be defined in the following way:
(defun dtr ( a ) (* pi (/ a 180.0)))
(defun rtd ( a ) (* 180.0 (/ a pi)))
Provided with a tangent of 0.26 recurring, you can obtain the corresponding angle in radians using:
(atan 300 1125) = 0.260602 radians
Alternatively:
(atan 0.266666667) = 0.260602 radians
Using the rtd function defined above, you can convert this to degrees:
(rtd (atan 300 1125)) = 14.9314 degrees
  • Thanks 2
Also look at angtos
(angtos 0.26 3)
"0.2600r"
(angtos 0.26 4)
"N 75d6'11\" E"
(angtos 0.26 1)
"14d53'49\""
  • Thanks 1
